stock 70 340 can help...
#1719592
01/01/15 09:18 PM
01/01/15 09:18 PM
Posts: 54 US
BLACK71
US
Been driving myself crazy trying to decide on a can swap for my 340....not going with anything outrageous just thought it'd be time for a little upgrade...I am looking for something "plug and play" and was looking at the Comp xe268h..but with the "kit" you can purchase through jegs/summit comps site says head machining is necessary...any advice or other can suggestions? Stock spec 70 340..auto...rear gears swap between 323 and 391.... Stock exhaust manifolds and a six pack on top...tires are 27" tall but will be running some smaller diameter drag radials for strip time...no power brakes etc so vacuum is not a huge concern..car has a 2500 stall converter also....sorry to bug everyone with another can choice thread but I am fed up enough with it all I was about ready to just buy the MP 488 cam
RMNS 10:9-10
Re: stock 70 340 can help...
[Re: BLACK71]
#1719593
01/01/15 09:27 PM
01/01/15 09:27 PM
Posts: 751 Saint Peters, MO
Brian
Saint Peters, MO
The XE268 is a perfect camshaft for that application.
1971 6.1 Gen III Hemi Duster
[Re: BLACK71]
#1719597
01/02/15 12:15 AM
01/02/15 12:15 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
You're right I looked at the wrong footnote...it said that it needs adjustable rockers?!?!
There are many SB mopars running that cam with stock style non-adjustables.
[Re: RobX4406]
#1719598
01/02/15 12:33 AM
01/02/15 12:33 AM
Posts: 54 US
BLACK71
US
And that's what I thought I busted wanted to make sure...do the kits maybe come with a different heighth lifter?
RMNS 10:9-10
[Re: BLACK71]
#1719599
01/06/15 12:51 AM
01/06/15 12:51 AM
Posts: 54 US
BLACK71
US
.....or what about a solid cam....
RMNS 10:9-10
[Re: BLACK71]
#1719600
01/06/15 01:06 AM
01/06/15 01:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Possible but if the lift is greater then that means the base circle is cut down deeper.. and if it is then the push rods will be short... if you know the difference of the base then you can figure the new push rod length... but I always like to measure the proper push rod length with the new cam in place and use a adjustable push rod to check it... if its a hyd cam find out what the company wants for pre-load and figure that in also if your not using adjustable rockers
[Re: BLACK71]
#1719603
01/09/15 01:13 AM
01/09/15 01:13 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Swapped a XE268H into my sons stock rebuilt 360 LA Long-Block using the stock valve gear.....ran like a scalded dog....no issues Weiand Stealth DP Manifold, 600 AFB, Long-Tube Headers. Rickster
