I need a water neck that won't leak #1719574
01/01/15 09:16 PM
01/01/15 09:16 PM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I have the Aluminum pump and housing and the chrome neck, the damn thing leaks no matter what...any ideas or help ?
Re: I need a water neck that won't leak [Re: 10secGTX] #1719575
01/01/15 09:23 PM
01/01/15 09:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Throw the chrome away, they are leakers, and get a new stock style neck. If you sand the chrome off flat and use sealer you may get it to stop leaking but it's a pain in the tail parts with no guarantee.
Re: I need a water neck that won't leak [Re: stumpy] #1719576
01/01/15 09:28 PM
01/01/15 09:28 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
only other option is to ante up for a billet one
Re: I need a water neck that won't leak [Re: TJP] #1719577
01/01/15 09:49 PM
01/01/15 09:49 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I know that this isn't a cheap solution . . . BUT - it WORKS !!! O ring seal !! Just need to use the 80's & up smaller size thermostat :
http://www.terrysautolab.com/
Well worth the money in my book !! No seepage, no leak . . . engine paint looks great !!!
Just my two cents worth . . .
Cheers,
Mark
Re: I need a water neck that won't leak [Re: a12rag] #1719578
01/01/15 10:39 PM
01/01/15 10:39 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
440source billet aluminum!
Re: I need a water neck that won't leak [Re: 10secGTX] #1719579
01/01/15 10:45 PM
01/01/15 10:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Fran I have a billet one from Mancini on my car and a Superformance gasket from Greg He also makes a gasket that will seal the leaky chrome ones once you make sure it's flat
Gus
64 Plymouth Savoy
Dana 60
Re: I need a water neck that won't leak [Re: 10secGTX] #1719580
01/01/15 10:54 PM
01/01/15 10:54 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The chrome one is a POS...
Made in China, never seals even when sanded smoothly, double gaskets..
U can spend the $ for a better billet one from Mancini...
Or go to Napa for this cast OE type for about $6.....
Part # BK 6051051
See the attachment..
Just my $0.02...
Re: I need a water neck that won't leak [Re: 10secGTX] #1719581
01/01/15 10:59 PM
01/01/15 10:59 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
How are you sealing it? I had this problem and I was using a gasket and clear silicon. My engine builder told me to throw away the gasket and just use good clear silicon. Allow it time to cure. I left it a day. The water neck hasn't leaked since. It's been 8 years.
Re: I need a water neck that won't leak [Re: 10secGTX] #1719582
01/01/15 11:05 PM
01/01/15 11:05 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Got an OEM thermo housing...
A gasket and some high-tack...
Been sealed for many years...
Re: I need a water neck that won't leak [Re: 10secGTX] #1719583
01/01/15 11:15 PM
01/01/15 11:15 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Aluminum OEM type housings are like $6 from most discount auto parts stores. I think the last one I got was from O'Reilly. Worked just fine.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: I need a water neck that won't leak [Re: 10secGTX] #1719584
01/01/15 11:26 PM
01/01/15 11:26 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I've always had good success just sanding both surfaces flat and sealing with silicone. No cleaners or solvents, just a sanded surface and a thin coat of silicone on each part. Let it set up a few minutes if you want. I think the cheap paper gaskets seep water.
Re: I need a water neck that won't leak [Re: @#$%&*!] #1719585
01/02/15 12:31 AM
01/02/15 12:31 AM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
I ordered the Mancini billet ..thanks
Re: I need a water neck that won't leak [Re: 10secGTX] #1719586
01/02/15 02:01 AM
01/02/15 02:01 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
napa
Re: I need a water neck that won't leak [Re: 10secGTX] #1719587
01/02/15 11:18 AM
01/02/15 11:18 AM
Virginia
RM21N0A Offline
RM21N0A  Offline
Virginia
I believe that pretty much any type EXCEPT the chrome ones will easily seal.
Years ago before I heard about all the problems with them, I got a chrome Mopar Performance neck through the local Dodge dealer.
Tried everything - double gaskets, homemade gaskets, washers for the bolts, different torque values - no joy.
You can actually see the curve in the mounting surface after installing/removing.
They are just made with very soft metal and distort very easily.
Re: I need a water neck that won't leak [Re: 10secGTX] #1719588
01/02/15 01:41 PM
01/02/15 01:41 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Now all you need is a quality gasket
Re: I need a water neck that won't leak [Re: roadhazard] #1719589
01/02/15 04:21 PM
01/02/15 04:21 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I took the cheapo chrome one from Mancini and put it on a belt sander and cut some of the material off nice and straight. Then used a cheapo FelPro Gasket with some FelPro Indian Head Gasket Shellac....no problems whatsoever
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: I need a water neck that won't leak [Re: @#$%&*!] #1719590
01/02/15 05:23 PM
01/02/15 05:23 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
I have done this as well and had good luck with it.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: I need a water neck that won't leak [Re: RM21N0A] #1719591
01/02/15 06:48 PM
01/02/15 06:48 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Exactly...
The chrome one has a thick base and distorts when hot...
Made in China out of recycled Coors cans, Mopar, Summit, Jegs, PAW and many auto stores including Oreily sold them..
I tried all the mentioned things...
Higher torque down
Sanding its base
Double gasket
No gasket w/RTV
High temp sealant
IMHO...
The root issue, is its material simply distorts after getting hot. Got the Napa one, installed new gasket, torqued it down...
No leaks 3 years later..
Just my $0.02...
