A518 shudder after warmup
#1719452
01/01/15 07:27 PM
01/01/15 07:27 PM
Posts: 51 Jacksonville, AR
dmckeehan
Jacksonville, AR
Recently installed a takeout a518 into my 1985 Crew cab W250 4x4. Kept the factory married NP205 transfer case. Pulled the pan, adjusted the bands and new filter before install. Fluid looked new in tranny before filter change. No burnt smell or anything. After the transmission is warmed up, i get a shudder in first gear at low rpm. Shudder stops before 1-2 shift. under heavy throttle, shudder stays till right before the 1-2 shift. light shudder on kickdown under heavy throttle. I'm thinking it may be clutches. Any suggestions?
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205 2002 3500 extended cab, 4x4, Cummins and 6 speed 1997 Ram 2500 5.9 with 35 Boggers - Mud Racer 1993 Dakota 4x4, Dana 60's front and rear - work in progress 1992 Dakota 2wd short bed, awaiting 440 swap
Re: A518 shudder after warmup
[Re: @#$%&*!]
#1719455
01/03/15 05:54 AM
01/03/15 05:54 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Does this shudder feel like the trans is slipping as first gear is the rear clutches and the sprag (overrunning clutch) holding? Also the direct clutches in the overdrive hold in first , second and third along with the sprag in the overdrive. Is it worse if you step on the gas harder or does the shudder feel more like a vibration type of shudder ? Have you tried manual low like was said ? Ron
[Re: 383man]
#1719456
01/03/15 06:45 PM
01/03/15 06:45 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Like Nemisis asked "Does it do it in manual low? (shifter in first gear)".
[Re: John_Kunkel]
#1719457
01/04/15 10:18 AM
01/04/15 10:18 AM
dmckeehan
Jacksonville, AR
Have not tried it in manual low, will try that this morning and get back with that info. At first i thought it was a ujoint, but all of those seem to be good. Yes, vibration/shudder is worse with more throttle. If it makes a difference, I have not hooked up the overdrive switches yet.
[Re: kenworth_goose]
#1719459
01/04/15 11:19 PM
01/04/15 11:19 PM
383man
Balt. Md
I think you have a band too tight.
There are no bands applied on take-off in drive. Ron
[Re: 383man]
#1719460
01/07/15 08:59 PM
01/07/15 08:59 PM
dmckeehan
Jacksonville, AR
Ok, got a chance to check it out. Still has the shudder when shifting manually through the gears.
