LA serpentine belt conversion?? #1718203
12/30/14 11:09 PM
12/30/14 11:09 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hello, I tried the search feature but no luck.. I want to add serpentine belt system to my 72 360 engine.. I have the mag timing covers, balancer, pulleys, WP, PS and alt brackets.. but noticed my LA heads don't have the bolt holes in them like the mags.. I have also heard bout using the b van 93-2003 PS bracket, does this bracket bolt to the lA head?.. has anyone done this? any pics? did you have to make the tensioner work?? any articles out there doing this?
Re: LA serpentine belt conversion?? [Re: Dakota_Don] #1718204
01/01/15 05:25 AM
01/01/15 05:25 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I believe that March makes a pulley setup, but not a true serpentine.
http://www.marchperf.com/chrysler-serpentine-pulleys.html
but other than modifying a magnum setup to work us MOPAR fans are out of luck.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
