440 to 426 motor mounts #1718179
12/30/14 09:49 PM
12/30/14 09:49 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
best source for mounts for conversion from 440 to 426 ? Shumacker has them for 259.00....was looking to save a few dollars...Thanks in advance...thanks moparts
Re: 440 to 426 motor mounts [Re: terzmo] #1718180
12/30/14 11:06 PM
12/30/14 11:06 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Shumacker is the only maker of these mounts.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 440 to 426 motor mounts [Re: HemiRick] #1718181
12/31/14 12:07 AM
12/31/14 12:07 AM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
John Arruzza makes Hemi mounts for V8 k-frames. http://www.arruzzahighperformance.com/Parts/Parts.html at the very bottom. Puts the engine 1/2in. lower than the Schumachers.
Don't cut corners on the mounts.
Re: 440 to 426 motor mounts [Re: Vert] #1718182
12/31/14 12:20 AM
12/31/14 12:20 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Get your Kframe done by Al Debevec, no cornor cutting there....715-267-7141
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 440 to 426 motor mounts [Re: terzmo] #1718183
12/31/14 01:55 PM
12/31/14 01:55 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
What kind of car? If you are building an E-body with a shaker hood, I recommend either buy a hemi k-frame, or have one converted, or use the Arruzza mounts. If your engine is 1/2 high, you'll have shaker fitment problems. If you add a Stage V intake manifold, you'll have problems. Other cars, not so much...
Re: 440 to 426 motor mounts [Re: Vert] #1718184
02/08/15 05:02 PM
02/08/15 05:02 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
I used the Schumacher mounts without first knowing it would change the shaker height making it too high.
A buddy let me try out his shaker to see how it would look using them.
Looks like I'll have to pull out the engine and sendin the K member.
Re: 440 to 426 motor mounts [Re: Topcat] #1718185
02/08/15 09:21 PM
02/08/15 09:21 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I built my own patterned after the Arruza mounts but stronger. His were tearing up holding up a little 426. Stage V intake on mine but I also built a lower aircleaner base.
Sheldon
Re: 440 to 426 motor mounts [Re: Topcat] #1718186
02/10/15 07:47 PM
02/10/15 07:47 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Not an optimal solution, but you might use 3/8 spacer between k-frame and rails. Some here said racers have used this method for years.
Re: 440 to 426 motor mounts [Re: Vert] #1718187
02/11/15 05:22 AM
02/11/15 05:22 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
schaumacker makes drop mounts,,,i have them.works out better...he also gave me a shim kit...so my hemi is where i need it to be now
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: 440 to 426 motor mounts [Re: sublimehemi] #1718188
02/12/15 06:00 PM
02/12/15 06:00 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Schumacher mounts put the engine high. I have them. OP has them. Other have them. If you dig up the correct measurements you'll probably discover you are 3/8 to 1/2 inch higher than spec. Regardless of what Schumacher says... I'm just waiting for the right time to replace mine with the Arruzza set I bought.
Edit: what is the shim kit about? Where do the shims go and how do they change the engine position?
