Re: Richmond 5 / 6 speed OD trans in 68 b-body?
[Re: bigD]
#171801
12/20/08 08:23 PM
12/20/08 08:23 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I put a Richmond 5-speed in my 64. In my case I had to cut and box my crossmember for shift-rod and shifter clearance with the Long V-gate as it's a tad bit larger than an H-pattern shifter.I also had to make my own tranny mount.They fit and work well but they are not a "bolt-in" installation.I think it was worth it though with that low (3.27) first gear so I can run a 3.54 gear in the rear. Here is a pic with a Long V-gate. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#171802
12/21/08 11:36 PM
12/21/08 11:36 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
Gus,it sounds like you did'nt have to mod the tunnel for the trans itself,just for the style of shifter you're running? I would be using an H pattern shifter,just wondering if it would locate in the stock location(I have a console).Thanks,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: bigD]
#171803
12/22/08 07:40 PM
12/22/08 07:40 PM
fourgearsavoy
Rittman Ohio
Well my car was originally a slant 6,3 on the tree car.I made my own tunnel to fit an E-body trans and shifter assembly.I liked the E-body trans for the shifter location right next to my thigh.I also used a Long V-gate shifter on the 833 Mopar 4-speed with the same tunnel.I custom made the shifter brackets and linkage for the Richmond so they came out in the same place as the 833 so I didn't have to do any more sheet metal work.It's alot of work and fabrication but like making your own headers it's all worth it when your done. Gus
