Re: How many folks keep there diesel truck plugged in full
[Re: Challenger 1]
#1717989
12/30/14 07:52 PM
12/30/14 07:52 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
never plug either of mine in (have to cycle the key once in a while)Dont see why you couldnt leave them plugged in 24/7, its a low wattage heater so no boiling should occur. If you did plug one in the only reson I can see for unplugging it would be save on the electric bill and to prevent pulling the socket out of the wall when you drive away which for me is teh biggest reason not to plug one in,
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: RUNCHARGER]
#1717992
12/30/14 11:28 PM
12/30/14 11:28 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I never plug my Dodge-Cummins in, that's what the GRID heater is for. My work Cummins and Volvo get plugged in if it gets down to zero Fahrenheit and the old Ford and GM diesels needed plugging in below about 10 fahrenheit it seems. I've started a Dodge Cummins at -40 not plugged in overnight.
Sheldon
As he says...A Cummins will start at almost absurd low temperatures without the block heater plugged in. I use mine occasionally, but it's more for the convenience of having a luke warm block so the windows defrost quicker. We get the "foggy" cold on the coast and the vehicle is usually covered with thick frost on a -10 morning. And diesels take frigging forever to warm up....
[Re: RUNCHARGER]
#1717995
12/31/14 01:59 PM
12/31/14 01:59 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
All of the newer diesels can start unassisted at -40 pretty easily. The block heater helps with engine wear though- it takes much longer than you'd expect to build oil pressure at those temps. If you plug it in, even if it's just for an hour or two before you'd want to start the truck, the oil will flow much easier and the crank speed will be faster.
[Re: Dragula]
#1717997
12/31/14 03:06 PM
12/31/14 03:06 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I plug mine in before I go to bed if it's going to get to 40 degrees or colder overnight. Not for the truck but for me, nearly instant heat. BRRR.
[Re: Guitar Jones]
#1717998
12/31/14 05:54 PM
12/31/14 05:54 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
My first winter with a diesel. And it's been mild. Just got the cord for the heater, haven't needed it yet, but I'm looking forward to having heat in the truck right away instead of having to drive 15 minutes before the temp needle even moves.
**Photobucket sucks**
[Re: 70Cuda383]
#1717999
12/31/14 10:38 PM
12/31/14 10:38 PM
Posts: 43,600 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
My 92 left me stranded on the road a couple of times because I couldn't plug it in at a motel. My 04 never needed to be plugged in. At work we plug the Internationals in (MaxxForce junk) 24/7 and only unplug them when we are ready to drive them.
JB Rhinehart, Realist
A-Body's RULE!
[Re: DaytonaTurbo]
#1718004
01/03/15 12:23 AM
01/03/15 12:23 AM
Posts: 1,261 Canada
Lugnutz
Canada
Yeah but a first gen with only a single battery, if that starts to get marginal at all you're in trouble!
I don't let it get marginal. I do live here and am familiar with our temps and weather...
