Rocker geometry on victors #1717712
12/30/14 04:12 AM
12/30/14 04:12 AM
ky, usa
littlejohn44 Offline OP
ky, usa
I just acquired a set of max wedge cnc ported victors that came off of a stroked 400. They came with crane 1.6 and hughes 1.6 offsets. I changed them to my shafts and was fixing the shims when I noticed the valves were hitting the springs. The guy i got them from said hughes set these up. Every retainer has marks all the way around the edge on intake and on the exhaust around the high point of the retainer. Exactly where each rocker hits on my mock up. Im not sure what retainer these are . I have checked valve length its correct. I am new to putting race motors together so i havent been around some of the thick spring stuff. I would have to do hella grinding just to get them to not rub. should the roller rocker be level with the roller just sitting on top of the valve? right now the valve sits so low in the retainer i dont know how the roller could make contact. it almost looks like the spring height is 1/8 to tall and the rocker is at an angle. With the rocker touching the roller tip sticks up over the valve tip about 1/8 inch. I will try and get pics tom-marrow but didnt know if someone had an idea from my babbling
Re: Rocker geometry on victors [Re: littlejohn44] #1717713
12/30/14 04:14 AM
12/30/14 04:14 AM
ky, usa
ky, usa
Do they shim up the rocker shafts for any reason? It has tall studs more than plenty for hold downs?
Re: Rocker geometry on victors [Re: littlejohn44] #1717714
12/30/14 04:45 AM
12/30/14 04:45 AM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
What is the installed height on the springs? About
1.900 is all you can get away with on those rockers with a 1.550 or bigger spring. After that the rockers have to be relieved to clear or a lot smaller spring installed. Hope this helps.
Re: Rocker geometry on victors [Re: littlejohn44] #1717715
12/30/14 08:38 PM
12/30/14 08:38 PM
USA
B3RE Offline
B3RE  Offline
USA
I know exactly what you are dealing with. The shaft needs to be raised and offset substantially to locate the rocker properly and have correct geometry.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Rocker geometry on victors [Re: DAYTONA540] #1717716
12/30/14 09:28 PM
12/30/14 09:28 PM
ky, usa
ky, usa
im gonna check that today, my machine shop guy is closed til the 5th so i didnt realize how much i depend on him. lol
Re: Rocker geometry on victors [Re: littlejohn44] #1717717
12/30/14 09:49 PM
12/30/14 09:49 PM
AndyF Online content
AndyF  Online Content
The Victor heads have really short valves which cause a bunch of problems in terms of spring height and room for the rocker arms.
You most likely need to work backwards from the valve lift that you're trying to hit. Once you know that you need to figure out how much room you have for a valve spring and then go spring shopping. A beehive spring would be perfect if you can find one that will work with your camshaft. If you can't find a beehive that fits then look at the small diameter "special" springs from PAC and others.
Re: Rocker geometry on victors [Re: littlejohn44] #1717718
12/30/14 09:49 PM
12/30/14 09:49 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
they were probably running lash caps
Re: Rocker geometry on victors [Re: BIGSTROKER] #1717719
12/30/14 10:33 PM
12/30/14 10:33 PM
USA
B3RE Offline
B3RE  Offline
USA
A longer valve would only make this situation worse, as would lash caps. The OP said the rocker had a lot of angle which would be made worse with this approach, not to mention have terrible geometry. The rockers are manufactured with plenty of clearance for the spring if the rocker is properly located. It needs to be moved to the right place!
Mike Beachel
Re: Rocker geometry on victors [Re: B3RE] #1717720
12/30/14 11:12 PM
12/30/14 11:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My question has always been this. How could a company that's made as many heads as Edelbrock, screw up the rocker shaft location on the Victors so bad? All I hear about these heads is how rockers and push rods don't fit.
Doug
Re: Rocker geometry on victors [Re: dvw] #1717721
12/30/14 11:30 PM
12/30/14 11:30 PM
USA
B3RE Offline
B3RE  Offline
USA
Doug
The question is "Where should they put it?". When the Chrysler designed the head, it was for a specific valve length, lift range, and rocker design. Considering most performance or race engines share none of these specs, how could they possibly put it in the "right" place?
Mike Beachel
Re: Rocker geometry on victors [Re: littlejohn44] #1717722
12/30/14 11:36 PM
12/30/14 11:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What diameter are the springs?
What's the installed height w/ the current spring & retainer combination?
Are either the retainers or locks designed to increase the installed height over "standard" pieces?
And, yes, pics would really help.
Re: Rocker geometry on victors [Re: BradH] #1717723
12/31/14 12:07 AM
12/31/14 12:07 AM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
Where should they put it? It's not that hard, the rockers were made to be used at 1.875 or 1.900 max installed height. They work there. If you need 2.00 installed height put a .125 longer valve in it.Cut the stands off and install blocks .125 higher than stock location. Not that tuff of a job for a good head shop to do.But I'm sure given some of the experts here it can be made into rocket science planning.
Re: Rocker geometry on victors [Re: B3RE] #1717724
12/31/14 12:21 AM
12/31/14 12:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Exactly, The factory Mopar head from 1962 has plenty of short comings. So I guess if I was designing a max wedge port race style head it would have started by using a 2" installed height 1.625" spring for a .750" lift cam that used existing rocker arms. I agree it's impossible to get it dead on for every combo. But lets at least get it close. I had to move my T&D stand on my -1s to get it where I wanted it. That being said the former owner of my heads ran them on his car for years with the rockers in the wrong position. At least the parts didn't crash into each other. I haven't seen one set of Victors that could be bolted together and run with out something hitting. I could understand that if they were something special. Why not just run -1s?
Doug
Re: Rocker geometry on victors [Re: dvw] #1717725
12/31/14 12:28 AM
12/31/14 12:28 AM
Good question but the Mopar Stage VI heads were also screwed up in a similiar fashion with a short valve and not much room for the valve spring. My guess is that the Edelbrock engineer just wasn't thinking about a 2.00 inch spring height when he did the CAD drawing.
From what I've seen over the years the rocker shafts need to go down not up. When you are opening the valve farther then the midpoint is lower not higher. So the shaft needs to drop into the head in order to get the correct geometry. Lowering the shaft is much more difficult than raising the shaft which is why most people don't bother. The Victor heads do have large flat pads in the correct place so Jesel rocker arms should fit. I haven't put Jesels on a Victor yet so I don't have any pictures to share but maybe someone else does.
Re: Rocker geometry on victors [Re: AndyF] #1717726
12/31/14 01:46 AM
12/31/14 01:46 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Since we are discussing moving the shafts, what do you think needs to happen to the shaft location in the attached picture and why? That picture was taken at full lift by the way.
To the original poster, DO NOT GRIND THE ROCKER ARMS! That is not the answer. With a little more information there are way more correct methods for resolving your issue. Get us more details and some pics.
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Rocker geometry on victors [Re: littlejohn44] #1717727
12/31/14 05:54 AM
12/31/14 05:54 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
It sounds like maybe you have offset retainers? Yeah, the Victors have their own set of hurdles. I run them and don't know anyone else personally who runs them but, that's the way I like it FWIW Here's my combo if it helps at all and, it's all just my 440/512 MW Victors, .674 sollid roller, Trick Flow springs TFS-16943-16(which are actually PAC-1243)installed at 1.900, Comp tool steel retainers 1732-16(very compact low profile), Comp CCA-4785-16 locators, 621-16 lash caps, Smith Bros .375x.083 pushrods, Harland Sharp S70016EVK rockers. No spring/retainer clearance issues even without lash caps. I decided to run the caps only because the sharp rockers sweep the roller toward the outer tips of the valves and wanted more contact. I'm sure it's not the ideal setup but seems to be working OK. Has been to 7400 RPM a couple times but keep it below 7k now. Also, don't forget about the possible center rocker stand breakage issue. I preemptively removed the factory helicoil and drilled/tapped and installed a 1.0 inch helicoil further into the head so the top of insert is just below bottom of stand. Learned that trick here on Moparts
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Rocker geometry on victors [Re: AndyF] #1717728
12/31/14 11:50 AM
12/31/14 11:50 AM
USA
B3RE Offline
B3RE  Offline
USA
Andy,
Do you have any data to show improved performance when lowering the stands to correct geometry with a roller rocker? My guess is you are treating a roller rocker the same as a stocker and inputting the wrong geometry points into your CAD models. They are not the same.
Another question, exactly what is proper geometry in your mind? In your book, you reference a bunch of different rocker brands, and their various fulcrum lengths, and claim you need to find the ones that that center the rollers on the valve stems to have good geometry. Now, you're talking about moving the shaft when increasing the valve lift. Which way is it? Talk about confusing!
As far as the stand location and height, it has absolutely nothing to do with spring installed height. the manufacturer can only account for their valve length when designing the head, and has no idea what rockers or camshaft the end user will install. A valve with the same length, but a different lock groove location, will have different installed heights but will retain the same geometry points. They will both take the same amount of correction to get the geometry right. I've done the Stage VI heads, and while they aren't my favorite head, they can have great geometry and spring clearance without grinding on anything.
I have pictures and more information on my website if that helps explain any better what I am getting at.
Mike Beachel
Re: Rocker geometry on victors [Re: MoParFish] #1717729
12/31/14 12:04 PM
12/31/14 12:04 PM
USA
B3RE Offline
B3RE  Offline
USA
I know it seems to run ok, but I wish you would address that sweep and get rid of the lash caps. With those rockers and that valve lift, you should only have .038" sweep across the valve when the geometry is correct. I'd hate to see you have an expensive failure down the road because the valvetrain is getting beat up.
Mike Beachel
Re: Rocker geometry on victors [Re: B3RE] #1717730
12/31/14 01:23 PM
12/31/14 01:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve always run lash caps on every motor small or big and never an issue so far...........I`d be curious about your product, prices etc.
Re: Rocker geometry on victors [Re: B3RE] #1717731
12/31/14 02:28 PM
12/31/14 02:28 PM
BradH Offline
BradH  Offline
Another example of HS BBM rockers' being too long between the pivot point and the centerline of the roller. Not a big fan of them, but I seem to be in the minority w/ that opinion.
