Re: Rocker geometry on victors
[Re: MoParFish]
#1717735
12/31/14 02:44 PM
12/31/14 02:44 PM
BradH
.674 sollid roller,
I'm right in the same ballpark lift-wise.
PAC-1243)installed at 1.900
Same springs & installed height.
Comp tool steel retainers...
I'm using ti retainers, which I'm good with as long as the springs don't have dampers that wear into them.
Smith Bros .375x.083 pushrods
I'll be getting some new SB pushrods, but plan to use .120" walls for this much spring pressure
Harland Sharp S70016EVK rockers.
Hughes' stuff on RAS shafts; no lash caps
Also, don't forget about the possible center rocker stand breakage issue. I preemptively removed the factory helicoil and drilled/tapped and installed a 1.0 inch helicoil further into the head so the top of insert is just below bottom of stand.
Did that to mine after seeing the posts on the broken center stands.
[Re: B3RE]
#1717737
12/31/14 03:04 PM
12/31/14 03:04 PM
Posts: 485 Central California
MoParFish
Central California
I decided to run the caps only because the sharp rockers sweep the roller toward the outer tips of the valves and wanted more contact. I'm sure it's not the ideal setup but seems to be working OK.
I know it seems to run ok, but I wish you would address that sweep and get rid of the lash caps. With those rockers and that valve lift, you should only have .038" sweep across the valve when the geometry is correct. I'd hate to see you have an expensive failure down the road because the valvetrain is getting beat up.
I hear ya and appreciate the advice I figure the only way to do it right would be to mill the stands and fit a paired Jesel setup but, if I went that route the engine would still be on the stand It's been in the car and running for over a year and I check the lash regularly. The HS rockers do seem a little long and also causes a fitment issue on the pushrod side of the rocker for some valve covers with the Victors. I ended up using fabricated aluminum covers and profiling the inside flange with a die grinder so I could slide the straight down over the studs. All good there now.
Also, found this pic where I ran a sweep pattern without the lash caps.
Sorry OP for the hijac. It's kinda related as us Victor guys need all the help we can get. We seem to be the underdog
[Re: MoParFish]
#1717738
12/31/14 03:14 PM
12/31/14 03:14 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Hopefully the OP doesn't mind me piggy backing a related question.
How does one remove the heli coil on the center stand to tap it deeper?
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: d7cook]
#1717739
12/31/14 03:25 PM
12/31/14 03:25 PM
MoParFish
Central California
I got in behind the original insert with a pick then grabbed it with a pair of needle nose pliers and twisted it back out. I then set the head up in the mill/drill press and used a close fitting drill bit as a centering device and clamped head. Then chucked the appropriate drill bit and drilled I beleive 1.250 inches further? below the bottom of the rocker stand then tapped new threads and installed the new 1.0 inch long inserts I got from MSC. I used an arp stud. I can probably find the part number if anyone needs it.
[Re: littlejohn44]
#1717742
12/31/14 11:08 PM
12/31/14 11:08 PM
MoParFish
Central California
its been a little colds here and i have been sick im hoping for some pics by this weekend. i got a rough measure of spring height and it looked to be way over 2.+. I am gonna change springs and retainers anyway. all the info you guys are spillin i keep it coming appreciate it. Thanks
Yep, sounds like they used offset retainers to run a taller spring which sinks the tip further into the retainer. If the spring is bigger than 1.550, that's not helping either. Hope you get to feeling better for the new year and Happy New Year All !!
[Re: AndyF]
#1717744
01/01/15 02:50 AM
01/01/15 02:50 AM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
The old Chevy Power engine book recommends having the rocker arm perpendicular to the valve at 2/3 lift. That is lower than the 50% or mid-lift recommendation that is most common.
Heres my two cents. The problem with the attached picture is the rocker arm is perpendicular to the valve at full lift. Not mid, not 2/3, but full lift. This is a .557 lift cam, 1.95 installed height on the springs and CAT Rockers. Although this results in greatest NET lift, it does affect valvetrain stability and other performance aspects. For argument sake, let say the only direction we can move the shaft is up or down. If we go down, the rocker will never be perpendicular to the valve stem in this application. Raising the roller tip by use of lash caps would also make our situation worse. Our only other hope to acheive the mid lift or 2/3 concept is to raise the shaft in relation to the valve.
I'm not saying there isn't an application that may require the shaft to be lowered or valve lash caps to be installed, I'm just saying that spacing the shafts up for proper geometry is necessary in some applications such as this.
All I can add is this, if anyone is having valvetrain issues or is curious about proper geometry, talk to Mike @ B3 Racing Engines. You won't find a nicer guy that is willing to go out of his way to help resolve your issues.
While my problems weren't relative to clearance, the geometry was incorrect. Shifting any higher than 5600 would result in loss of perfromance. After correcting my geometry, I can shift the car at 6500 with no loss of performance. I can"t thank Mike enough. Give him a call before you buy other parts or grind on your stuff. I think you'll be glad you did.
[Re: MoParFish]
#1717745
01/01/15 03:06 PM
01/01/15 03:06 PM
BradH
I tried to locate a comparable photo (I thought?) I took of mine w/ the Hughes rockers, but came up w/ nothing...
What I do remember is that the pattern was definitely narrower, although a bit biased on the intake-side of the valve tip (starts on the intake side and ends up closer to the center at max lift).
Amen, brother!
[Re: Jeremiah]
#1717747
01/01/15 04:22 PM
01/01/15 04:22 PM
MoParFish
Central California
So you guys don't like the Isky RAD-9999 springs for these heads?
Specifications: Style: Dual with Damper Outer OD/ID: 1.600"/1.150" Inner OD/ID: 1.040"/.745" Seat Pressure: 250 lbs. @ 2.000" Open Pressure: 770 lbs. @ 1.200" Rate: 650 Coil Bind: 1.150" Max Lift: .800"
They are 283 @ 1.950 and 7838 @ 1.250
I'm sure they're great but when Dwayne Porter spec'd my cam he recommended a spring similar to the Comp 943-16 around a 550lb spring rate so, I chose the TFS-16943-16 (PAC-1243). Plus, I wanted to run locators and standard height retainers and locks and with this combo it ended up scary close to the spec'd 1.90000 installed.
By the way FWIW I'm running these heads OOTB out of the box. No port work, clean up or valve job. I was tempted to at least clean up the cast flashing but, wanted to know what they would do truly OOTB. I checked factory valve contact with Prussian blue, assembled and bolted 'em on. Well, I guess I did fix the center rocker stands so maybe OOTB "flow-wise". Car with me is 3785 and has gone [Email]10.33@130[/Email] in good air. I'm sure I'm leavin some on the table but does OK for now. More info on engine combo about half way up the page
[Re: MoParFish]
#1717748
01/01/15 05:50 PM
01/01/15 05:50 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Sounds like a righteous package to me. It really moves that weight. There is more cam and engine info in my 66 Charger build thread if you want to take a look. My Victors are Hughes' CNC program/valve job with a .740ish net lift roller so it's bit different. I have been told to stay with a higher end spring like the PAC, Isky Tool Room or Manley Nextek stuff. It's hard to find a spring in a diameter larger than 1.550 that will work out at a 1.950 installed height.
