Wiring WWYD?
#1717614
12/30/14 01:35 AM
12/30/14 01:35 AM
moparpollack
Lil Herman
Lil Herman
85086
The lugs to my ammeter were cut is there any harm in bypassing the ammeter and closing the loop by soldering or crimping these together? Or is there a better solution?
Re: Wiring WWYD?
[Re: moparpollack]
#1717616
12/30/14 01:40 AM
12/30/14 01:40 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes connect them together on the OTHER side of the plug in the firewall. I.E. connect them in the engine compartment. The weak point in this system is the brass connectors in the firewall plug, eliminate them.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Wiring WWYD?
[Re: moparpollack]
#1717617
12/30/14 01:43 AM
12/30/14 01:43 AM
RapidRobert
all current runs thru that connection so make that a tight/clean/secure/good continuity connection wrapped well with tape when done
Re: Wiring WWYD?
[Re: RapidRobert]
#1717618
12/30/14 01:50 AM
12/30/14 01:50 AM
moparpollack
Lil Herman
Lil Herman
85086
Thanks for the replies! ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Wiring WWYD?
[Re: HemiRick]
#1717620
12/30/14 01:19 PM
12/30/14 01:19 PM
Posts: 9,895 MI, usa
dvw
MI, usa
You can definitely connect them together on the engine compartment side. But make they still feed into the dash. They are the power feed for everything in the dash, headlamps, heater, ignition, etc. Doug
Re: Wiring WWYD?
[Re: burdar]
#1717622
12/30/14 05:10 PM
12/30/14 05:10 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My 65 I connected them about 25 years ago as the amp meter was burning.The stock amp gauge is bad as are any after market ones if the factory wiring is left as is.The after market will burn quick on most I know.I install volt gauges now.Even into the late 70 the Mopar amp gauges were junk as all of my Rams had problems with them.I eliminated all of them and volt meters went in.Rocky
Chrysler Firepower
