67-68 barracuda fast back interior door panel the same? #1717345
12/29/14 02:35 PM
12/29/14 02:35 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
are there any diffrences between the two years between the door panels both front and rear?
67 are on sale for $100 less.
thx Ted
Re: 67-68 barracuda fast back interior door panel the same? [Re: Diego_Ted] #1717346
12/29/14 02:38 PM
12/29/14 02:38 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
thx Ted
Yes, difference every year and there is a unique standard and deluxe version each year too.
The repro 68 and 69 deluxe's are more expensive than the standards. Note sure about 67, because they might not come with the woodgrain/aluminum inserts.
Where are these on sale?
Re: 67-68 barracuda fast back interior door panel the same? [Re: autoxcuda] #1717347
12/29/14 02:41 PM
12/29/14 02:41 PM
Diego-Town, CA
Diego-Town, CA
PG classics, has the 67 FB on sale? are all the holes the same? I don't care about PC correctness?
thx Ted
Re: 67-68 barracuda fast back interior door panel the same? [Re: Diego_Ted] #1717348
12/29/14 02:49 PM
12/29/14 02:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
thx Ted
The door panel holes are the same. Any 67-72 A-body hardtop door panel will actually snap on.
The rear panals are unique to 67-69 Fastback. Between 67-69 fastback they all with snap on interchange.
Re: 67-68 barracuda fast back interior door panel the same? [Re: Diego_Ted] #1717349
12/29/14 02:57 PM
12/29/14 02:57 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
thx Ted
These?: http://www.pgclassic.com/product_info.php?products_id=1282
PUI interiors also has cheaper door panels than legendary too. Might look into those also.
Beware some of these lower quality door panels are not cut correctly and will show bumps and lumps on the door panel where every trim clip is. Some people have cut reliefs in the back of the cardboard and thinned down the trim clips.
Might want to test fit one clip on the bottom of the panel to see if the look is ok with you before installing all the trim clips.
Re: 67-68 barracuda fast back interior door panel the same? [Re: Diego_Ted] #1717350
12/29/14 06:06 PM
12/29/14 06:06 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
thx Ted
Unless they are really inexpensive (like 1/2 price or less) I would not go with PG classics. Very poor customer service record.
I'd check with BE&A.
Re: 67-68 barracuda fast back interior door panel the same? [Re: autoxcuda] #1717351
12/29/14 08:01 PM
12/29/14 08:01 PM
Diego-Town, CA
Diego-Town, CA
thx Ted
Yea those are the ones I was looking at. Price is right, not a concourse resto just presentable. So they will work correct.
thx Ted
