Re: Replacating factory spot welds
[Re: Grizzly]
#1716974
12/28/14 04:37 PM
12/28/14 04:37 PM
Posts: 4,848 Memphis
HemiRick
Memphis
At best a MIG welder can only come close. The only thing that can perfectly replicate a spot weld is a spot welder. A wire brush works good for locating the spot welds, and a spot weld cutter is invaluable. An air chisel is your friend when removing the old metal.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: mopar4ya]
#1716977
12/28/14 05:38 PM
12/28/14 05:38 PM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Dan, that is going to be tough! Recently I was looking online at spot welders & there seem to be units that are not too expensive & look like they'd do the job. I remember using one back in my metal shop class in junior high - it was easy to use & worked great. If I was going to do a major sheetmetal job like this, I would invest in one. Whenever I go to car shows, I look at all the restored cars & I look closely for cars that have had sheetmetal work done so well that you can't tell they are not factory - and that means perfectly duplicated spot-welds! You almost NEVER see that! Good luck & all I can say is I don't know how you did it to have your daughter interested - but my hat is off to you. Neither of my daughters could care less about my Cudas.
[Re: Sunroofcuda]
#1716978
12/28/14 05:58 PM
12/28/14 05:58 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
with as much, metal as you are doing, thats a lot of time to drill, plug weld with the mig, trying to get the factory look We recently purchased a Lenco because we couldn't find a used one at the time.. of course, right after that 2 showed up for sale... We really like it, Very easy to use we are practicing, on a 72 Dart welding in floors, spare tire area. We bought it mainly to do a 340 Dart> quarter panels, full floor and the Cuda quarter panels. both these cars wanting factory look welds When finished, there will be no problem selling the welder. Try placing a wanted ad> local to you There is not much inside of one to go bad. (transformer, timer, relay) they either work or not. mostly keep the tips clean
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: draginmopars]
#1716982
12/28/14 11:28 PM
12/28/14 11:28 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
So the lenco doesn't require jaws that limit access such as deep inboard on the floor. You just have to line the 2 leads up and pull the trigger? Very interesting.
Thank you.
Careful, your character's showing!
[Re: mopar4ya]
#1716983
12/28/14 11:32 PM
12/28/14 11:32 PM
Posts: 618 Vesper,Wisconsin U.S.A
DusterJeff
May I suggest practicing on some scrap pieces of metal the same thickness as your patch panels. When I do my "SpotWelds" with the MIG on my Duster, I run .023 wire in the gun.Takes a bit of "Practice" to get a good "Rosette" looking weld.... Good luck on your Father-Daughter Project....
Do Something..Lead..Follow..or get the {Beep} out of the way..
[Re: mopar4ya]
#1716984
12/28/14 11:34 PM
12/28/14 11:34 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have seen one collecting dust at Mike Ross's shop over at B/E&A Restorations.It's a big professional collision repair unit and he might be interested in selling it. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: mopar4ya]
#1716986
12/28/14 11:56 PM
12/28/14 11:56 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
I would not be against a Lenco spot welder, but from what I have heard you can't get a strong enough weld. I think the problem is on areas like the pans to the rails where the rail is much thicker metal and you can't get enough penetration to make it structurally strong. Is there any truth to this?
yes its true i have seen stuff welded together with one that could be pulled apart by hand! i would not trust one myself i was thinking of getting a used one not to take the place of plug welding but just for cosmetics instead of using a pencil eraser. i have also seen cylindrical die cutters used for replicating spot welds that have looked pretty authentic.
[Re: mopar4ya]
#1716987
12/29/14 01:08 AM
12/29/14 01:08 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I would really suggest evaluating how important having correct looking spotwelds are before I would spend the money and time to try to duplicate them. From someone that has literally performed millions of spotwelds and performed destructive testing on them in a manufacturing environment, I can tell you it isn't as simple as holding a couple tips together on a couple pieces of sheet metal. I've probably cut apart 20 full bodies to test spotweld integrity, so I kind of know a little about them. You can't tell a good spotweld by it's looks, so you are left to using a proper, repeatable process to make strong welds, which is almost impossible in a shop setting.
A good spotweld takes the correct current for the proper length of time, proper tip diameter (to heat the metal without burning it) and alignment, proper clamping pressure, and clean materials CONSISTANTLY to perform. While you can have decent results from the stationary machines with the footpedal - it takes a lot of trial and error to get REPEATABLE results, and they are limited to panels that you can fit between the arms.
Many times in the You Tube videos I see people performing spotwelds with the two handheld contacts, and I see that a lot of the time they have spatter coming from between the panels, which indicates they don't have enough clamping pressure between the tips. Those welds typically WILL FAIL TESTING, due to the panels didn't melt together fully. I don't see how anyone can CONSISTANTLY apply the correct pressure required, which can be 100+ lbs in certain circumstances, with handheld contacts in a shop environment.
I also see people "test" their welds by putting several welds into the ends of two pieces of sheetmetal, and try to pull them apart - LOL. The CORRECT test is 1 weld, and trying to twist the 2 apart - if the weld is good, you will tear a hole out of one of the sheets of metal - a bad one the weld fails. Or a chisel between the sheets to see if the weld pops before the metal tears. Point is, you have to make it fail to test the weld - many good looking spotwelds will fail testing. While they can produce acceptable results under controlled conditions, I don't see how someone could produce consistant spotwelds in a shop environment, especially with the handheld contacts.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: screamindriver]
#1716990
12/29/14 04:54 PM
12/29/14 04:54 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've heard of people grinding the plug welds flat then using a fresh pencil eraser in the wet paint to replicate the spot welds.
[Re: Stanton]
#1716991
12/29/14 10:17 PM
12/29/14 10:17 PM
Posts: 2,655 western PA
mopar4ya
western PA
If its "looks" you're after then go ahead and spotweld it. If you want it solid and safe, mig plug welds are the ticket.
Believe me, solid and SAFE is the only way I will build this car. My daughter is a graduate of Shriners hospital, she's been through enough in her young life, looking to build something she will enjoy in the years ahead.
Thanks Dan
