RB Engine ID help needed #1716930
12/28/14 02:26 PM
12/28/14 02:26 PM
Arizona
az426john Offline OP
Arizona
We are trying to ID the engine block in my buddy's 1969 Charger.
The numbers on the pad adjacent to the distributor hold down are as follows:
Line 1 - 5T 10 E
Line 2 - 5 28
Any help would be appreciated.
Re: RB Engine ID help needed [Re: az426john] #1716931
12/28/14 03:02 PM
12/28/14 03:02 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
5T IS 1975 440,E is cast crank,5 28 is may 28 assy date.
"Long Live Mopars"
Re: RB Engine ID help needed [Re: Furyman] #1716932
12/28/14 04:44 PM
12/28/14 04:44 PM
Arizona
Arizona
Thank you Sir!!
Re: RB Engine ID help needed [Re: az426john] #1716933
12/29/14 06:31 PM
12/29/14 06:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Line 1 - 5T 10 E
Line 2 - 5 28
5 is 1975
T is Trenton Assembly plant
10 ????
E is cast crank
5 28 is May 28 1975 assembly date
Re: RB Engine ID help needed [Re: JohnRR] #1716934
12/29/14 07:11 PM
12/29/14 07:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 10 is probably a soft-stamped 440
