Page 2 of 5 1 2 3 4 5
Re: Diesel Dart Cummins [Re: DieselDart73] #1716553
12/31/14 10:16 PM
12/31/14 10:16 PM
Eastern Pa
DieselDart73 Offline OP
Eastern Pa
And the other truck the guy who built this one runs a 727 in it goes 11.2s all day and hasn't broke anything other then universal and pinion on the 9in. This is the first dodge trans I'm doing. I love my Mopars we have a lot in my family. Seven to be exact. I've always done the ford trans in my tow rigs most Suncoast part and precision.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716554
01/01/15 03:10 AM
01/01/15 03:10 AM
Eastern Pa
Eastern Pa
Ok back to the cage. It's done now and front bars up front
Re: Diesel Dart Cummins [Re: DieselDart73] #1716555
01/01/15 11:29 PM
01/01/15 11:29 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Thanks a lot. We'll have it out your way at one of the tracks. Norwalk national trail Thompson or la rue. See it in person.
If it is at LaRue or National Trail I would make the tri to check it out for sure!
1969 Dart GTS 340
1969 Coronet R/T X9 N-96
1999 Dodge Dakota R/T RC
2015 Dodge Dart GT
2019 Ram 2500 Big Horn
Re: Diesel Dart Cummins [Re: OhioMopar] #1716556
01/02/15 03:46 PM
01/02/15 03:46 PM
Eastern Pa
Eastern Pa
It'll be at laRue look up nadm for the dates. I'll have many passes on the car by the time we make it there.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716557
01/03/15 02:16 AM
01/03/15 02:16 AM
Eastern Pa
Eastern Pa
Here's the narrowed up rear
Re: Diesel Dart Cummins [Re: DieselDart73] #1716558
01/03/15 02:23 AM
01/03/15 02:23 AM
Boise, Idaho, U.S.A.
tims69belvedere Offline
Those rh's can live. Decent clutch packs and bands. Some had an aluminum front planet. You will need a steel front planet. I would rollerize the gear train. Billet input and intermediate shafts with the second gear updates. A light car Like that shouldn't be too hard on it. Wouldn't hurt to do a direct drum. We do these all the time. Can't hardly keep them in the shelves. One customer keeps us busy with his. 1600 hp on fuel only in a regular cab 4wd. It's a race truck but the convertor has become the weak point. Sweet build though!
Re: Diesel Dart Cummins [Re: tims69belvedere] #1716559
01/03/15 02:32 AM
01/03/15 02:32 AM
Oh and can't forget the valve body mods to have 1st and 2nd gear lockup!
Re: Diesel Dart Cummins [Re: DieselDart73] #1716560
01/03/15 05:08 PM
01/03/15 05:08 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Cool project! I think you're gonna need some fatter torsion bars....lol.
Re: Diesel Dart Cummins [Re: JDMopar] #1716561
01/03/15 05:27 PM
01/03/15 05:27 PM
Eastern Pa
Eastern Pa
Believe it or not those are the slant6 torsion bars. Lol being that the engine is moved back as far as it is it's really stiff up front. It's really amazing. Well test it and see where to go from there.
Re: Diesel Dart Cummins [Re: DieselDart73] #1716562
01/03/15 05:44 PM
01/03/15 05:44 PM
JDMopar Offline
JDMopar  Offline
You can buy bigger bars if needed. I would gusset the torsion bar frame stubs that are left, if you aren't going to tie the torsion bar cross member back together. With the motor scooted back, you may not have room to tie it back together. As long as the remaining sections of the torsion bar x member won't twist, they will be fine. It'd be hell to come down from a hard wheels up launch....and the drivers side torsion bar jab you in the back of your left leg!
Re: Diesel Dart Cummins [Re: JDMopar] #1716563
01/03/15 06:04 PM
01/03/15 06:04 PM
Eastern Pa
Eastern Pa
How's this look?
Re: Diesel Dart Cummins [Re: DieselDart73] #1716564
01/03/15 06:12 PM
01/03/15 06:12 PM
JDMopar Offline
JDMopar  Offline
Awesome! Is that a motor mount/ plate towards the mid to rear of the engine?
Re: Diesel Dart Cummins [Re: JDMopar] #1716565
01/03/15 06:42 PM
01/03/15 06:42 PM
Eastern Pa
Eastern Pa
Yes it's coming along
Re: Diesel Dart Cummins [Re: DieselDart73] #1716566
01/05/15 04:04 PM
01/05/15 04:04 PM
Eastern Pa
Eastern Pa
Here's the strengthened 8 3/4 and narrowed
Re: Diesel Dart Cummins [Re: DieselDart73] #1716567
01/05/15 04:05 PM
01/05/15 04:05 PM
Eastern Pa
Eastern Pa
Another view 8 3/4 narrowed
Re: Diesel Dart Cummins [Re: DieselDart73] #1716568
01/05/15 05:23 PM
01/05/15 05:23 PM
Eastern Pa
Eastern Pa
With 4 link attached
Re: Diesel Dart Cummins [Re: DieselDart73] #1716569
01/06/15 12:51 AM
01/06/15 12:51 AM
Eastern Pa
Eastern Pa
Rear end mock up and coilovers back half
Re: Diesel Dart Cummins [Re: DieselDart73] #1716570
01/06/15 10:57 AM
01/06/15 10:57 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Looking good!
Re: Diesel Dart Cummins [Re: DieselDart73] #1716571
01/20/15 01:16 PM
01/20/15 01:16 PM
Eastern Pa
Eastern Pa
Engine bay prepped for paint
Re: Diesel Dart Cummins [Re: DieselDart73] #1716572
01/20/15 01:17 PM
01/20/15 01:17 PM
Eastern Pa
Eastern Pa
Painted up
