Re: 71 satellite engine swap
[Re: forphorty]
#1716449
12/28/14 02:19 AM
12/28/14 02:19 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
I am confused as well, if your motor and trans were connected before you dropped it into the engine bay then why are the flex plate bolts not in and tight? And if the trans is in place on the motor then there should be nothing to adjust to get the motor mounts to drop on the K frame, you should have plenty of room to move the motor and trans back and forward to line up the mounts.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: 3rdGenBbody]
#1716452
12/28/14 09:57 PM
12/28/14 09:57 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
If I understand correctly you have the engine bolted to the transmission but can't turn the convertor to line up holes with the flex plate.
Is the back of the block flush against the transmission bell housing or is there a space there? Were you careful to make sure the convertor pump drive hub was properly seated into the front pump? If it is, you should have enough clearance for the convertor to spin without a problem.
The front hub on the convertor has to nest into the opening on the crank flange. If it's cocked at all you'll have trouble. I don't think the balance weight would be the problem. I ran into this problem putting a 360/727 in a b body this fall. The convertor was new, and I'd double checked everything before bolting them together, but still had a problem. Loosened up the bell housing bolts and wiggled things a bit and it all lined up properly.
Not sure if this helps or not. Best of luck.
Lead, follow or get the hell out of the way
