46re firm shifts #1716334
12/27/14 10:58 AM
12/27/14 10:58 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
is the 727 mods usable on the 46re ?
its time to step up to a track only transmission but not whit manual valvebody ,whant nice firm shifts
need some advice on the valvebody ,hole size etc
the solid servos ,accu blockerods etc i have
Re: 46re firm shifts [Re: Tobbe] #1716335
12/27/14 11:00 AM
12/27/14 11:00 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
more
Re: 46re firm shifts [Re: Tobbe] #1716336
12/27/14 11:03 AM
12/27/14 11:03 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
more pics
Re: 46re firm shifts [Re: Tobbe] #1716337
12/27/14 07:06 PM
12/27/14 07:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pic #1 is a ball blocking the 1-2 shift control valve, makes the 1-2 shift firmer at all throttle settings.
Pic #2 passage wall removed increases fluid flow to the 2-3 shift valve.
Pic #3 is a blocker rod for the shuttle valve, used in most cheap plate kits but not in reprogramming kits.
If you're gonna block the accumulator be sure not to use a plastic piston.
Separator plate holes sizes same as 727.
Re: 46re firm shifts [Re: John_Kunkel] #1716338
12/27/14 07:10 PM
12/27/14 07:10 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
ok what do the blocker rod for the shuttle valve do?
i whant firm shifts ,one step below running full manual vb
//T
Re: 46re firm shifts [Re: Tobbe] #1716339
12/27/14 09:02 PM
12/27/14 09:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The shuttle valve softens the shift when the throttle is lifted. Why one would want to eliminate this function is beyond me.
Re: 46re firm shifts [Re: John_Kunkel] #1716340
12/28/14 07:10 AM
12/28/14 07:10 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
ok thanks for your reply you are an transmisson god ,i have a spare valvebody so i could do everything and change back to oem if i dont like it .
any more mods you could think of ? (valve body)
i dont like the restriktor in the direct feed channel always put in more springs in direct drum and run 3.8 or 4.2 ration on kickdown band
Re: 46re firm shifts [Re: Tobbe] #1814684
04/29/15 05:33 PM
04/29/15 05:33 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
small bump here , is this a common mod ?
http://cardiagnostictools.devhub.com/blo...ottle-response/
Re: 46re firm shifts [Re: Tobbe] #1814939
04/29/15 11:16 PM
04/29/15 11:16 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
What are you doing to set your shift rpms?
Re: 46re firm shifts [Re: Tobbe] #1815389
04/30/15 01:40 PM
04/30/15 01:40 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
shiftpoint /sct tune ,i dont now if the signals could be altered/piggiback
