Magnum oil filter adapter plate on LA? #1715784
12/26/14 11:22 AM
12/26/14 11:22 AM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Hope everyone's Christmas was a good one!
I see that Dodge still makes an oil filter adapter plate for the 5.9L, it looks very much like the one for the LA but 5 holes that look slightly bigger. Anyone know if this fits the LA blocks? Would the nut be the same? All the best for the Season
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Magnum oil filter adapter plate on LA? [Re: busboy] #1715785
12/26/14 03:00 PM
12/26/14 03:00 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
I am not sure if the magnum is compatible? But I do drill four more holes in the stock LA piece.
Re: Magnum oil filter adapter plate on LA? [Re: dezduster] #1715786
12/26/14 03:08 PM
12/26/14 03:08 PM
Delta, B.C. ,Canada
Onetorun Offline
Onetorun  Offline
Delta, B.C. ,Canada
Yes the magnum will fit LA,I went from right angle adapter on a LA to this not long ago, as mentioned drill and chamfer 4 extra holes for oil flow and your good to go.
Re: Magnum oil filter adapter plate on LA? [Re: Onetorun] #1715787
12/27/14 03:20 PM
12/27/14 03:20 PM
busboy Offline OP
busboy  Offline OP
Thanks for the reply's. Got everything ordered up through the local dealer. Much appreciated.
