Page 8 of 10 1 2 6 7 8 9 10
Re: Air filters on race cars?? *DELETED* [Re: Thumperdart] #1715205
01/04/15 06:47 PM
01/04/15 06:47 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Post deleted by mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Air filters on race cars?? [Re: mopar65] #1715206
01/04/15 07:16 PM
01/04/15 07:16 PM
mi
RATPATROL Offline
RATPATROL  Offline
mi
edelbrock air cleaner comes with k&n filter, not sure on filter size cars in storage sorry.
Re: Air filters on race cars?? [Re: mopar65] #1715207
01/04/15 11:29 PM
01/04/15 11:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The trick seems to be to run enough filter surface area not to measurably restrict.
For example, Holley ran a test in 1971 of air flow through a carb.
No air cleaner 713 cfm
Chevy hi-perf open element cleaner 675 cfm
Same as above but with two filter elements stacked 713 cfm.
They didn't publish the hights, but the point is once they had enough area, the restriction was the carb. (Mike Urich and Bill Fisher Holley Carburetors & Manifolds 1987 edition page 71)
Another thing to consider along the line of what Mr P was describing is the impact on the bowl vents. With Holley type carbs the vent could be placed into a pressure stream, or in a weird turbulent area and that can mess up the fuel curve. A ton of ideas on modifying Bowl Vents shared at Racing Fuel Systems.
Been installing an 11/32 brass sleeve over the bowl vents and I drill 4 holes in em and they work. No more pulling fuel up the tubes and the top of the carb`s cleaner. They work for those situations like mine were the lid touches the scoop or is real close.........
hey Dom don't know if you would be interested in this air filter. i found it while doing research on some air filters for my tunnel ram. it says you don't need a base or air filter lid with this one. its said its for people that don't have a lot of under hood room.
http://www.r2cperformance.com/holley-dominator-air-filters.aspx
Thankxxx man and cool stuff............. I got a Wix racing 3 1/2" air filter and after a few tweeks, the hood fits tight w/no lid just the rubber on the filter against scoop so we`ll see how it runs and how/if the WB see a difference good or bad.
Re: Air filters on race cars?? [Re: Thumperdart] #1715208
01/05/15 02:04 AM
01/05/15 02:04 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Here my new UNI.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Air filters on race cars?? [Re: WadeMetzinger] #1715209
01/05/15 02:15 PM
01/05/15 02:15 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I just ran a tnt this sat at Sac. I don't normally run an air cleaner but the one I have and do run is just a Moroso 14 inch with a K/N 4 inch filter. I threw it on and mph went up almost .8 mph I need more fuel and the motor was still pulling through the traps. I plan to find out how much more fuel I can throw at it and run the filter.
Re: Air filters on race cars?? [Re: BradH] #1715210
01/05/15 03:02 PM
01/05/15 03:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not sure if running a smaller (more restrictive) filter setup on the street, and switching out to something more of a "bird and rock catcher" screen only at the track, is a viable approach... or if that's simply fooling myself.
1. ... 'cuz I was hoping for a comment or two in response to my last paragraph.
2. Where can flow test results for the Wix racing filters found? All I've noticed is the parts listings on Summit, et al, simply say "flow 1000+ CFM"... but it's the same "spec" regardless of size.
Re: Air filters on race cars?? [Re: BradH] #1715211
01/05/15 04:27 PM
01/05/15 04:27 PM
BradH Offline
BradH  Offline
Just came across this thread on another forum: http://forums.tccoa.com/showthread.php?t=15773
Even though it's from 2003, the data is still valid IMO and the preface by the poster on the test methodology is also interesting.
Re: Air filters on race cars?? [Re: BradH] #1715212
01/05/15 05:54 PM
01/05/15 05:54 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i run the K&N extreem's on my dart. Runs exactly the same ET with or without them so there always on. i clean the tops about 3x more often then the round element. you can defiantly tell it pulls all the air from the top.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Air filters on race cars?? [Re: BradH] #1715213
01/05/15 07:49 PM
01/05/15 07:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So this chart is only measuring air thru a filter only no other in line restrictions? I would have not guessed a 25% increase in filter area (14x3 to 14x4) would only gain a much less percentage of air flow. Actually i would have guessed more, thinking the media mounting ends would disrupt air flow, and a taller filter would have less turbulence.
Re: Air filters on race cars?? [Re: BradH] #1715214
01/05/15 08:09 PM
01/05/15 08:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
First off, THIS is the reason I joined Moparts and a select few sites because of valuable info like this post is getting not squabbling bs like grade school kids in the sand box..............I agree about the 1000+ cfm in different sizes and would like closer more accurate data than that. Think I`ll call em.............
Re: Air filters on race cars?? [Re: Thumperdart] #1715215
01/05/15 08:18 PM
01/05/15 08:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think if you call them your gonna get some bogus
number.. IF they even know... you would be talking
to a salesman... I agree.. I would have figured a
larger difference from a 3" to 4"... something just
doesnt sound right
Re: Air filters on race cars?? [Re: BradH] #1715216
01/05/15 10:37 PM
01/05/15 10:37 PM
AndyF Offline
AndyF  Offline
That is a good chart, I haven't seen it before.
I've always used a 14x4 as the minimum air cleaner size for a performance engine. I use the 14x6 K&N for dyno testing. The 14x6 should flow about 1600 cfm on that guys test setup since it is double the area of the 14x3.
Re: Air filters on race cars?? [Re: AndyF] #1715217
01/06/15 12:01 AM
01/06/15 12:01 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
14x3 = 131.94sq" filtering area
14x4 = 175.92sq"
The 14x3 has 3/4. (75%) of the surface area of the 14x4
Unless its made out of a different material, or is thicker...I cant see how the 14x4 only flows 5.4 %. more!
907/860 x 100/1 = 105.4%.
Re: Air filters on race cars?? [Re: Moparmal] #1715218
01/06/15 12:32 AM
01/06/15 12:32 AM
AndyF Offline
AndyF  Offline
Yes, it calls into question the test method and/or the filters used. The airflow should increase roughly the same as the area so one of those numbers is wrong.
Re: Air filters on race cars?? [Re: AndyF] #1715219
01/06/15 12:35 AM
01/06/15 12:35 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What if the measurement/test was thru say 1000cfm carb or something else that gave an upper limit to the flow?
Re: Air filters on race cars?? [Re: jcc] #1715220
01/06/15 12:44 AM
01/06/15 12:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If thats the case then a lot of the data might be invalid ..
who is to say that choke point didnt hold back flow
on some of the 3" stuff
Re: Air filters on race cars?? [Re: MR_P_BODY] #1715221
01/06/15 05:01 AM
01/06/15 05:01 AM
Moparmal Offline
Moparmal  Offline
If people want to use the K&N formula - then this s how u calculate the surface area of a round filter.
Its circumference x height - Plug in the diameter into this calculator and itll tell you the circ.
Then x by height -
http://www.csgnetwork.com/circle_sphere_area_calculator.html
Re: Air filters on race cars?? [Re: Moparmal] #1715222
01/06/15 11:49 AM
01/06/15 11:49 AM
BradH Offline
BradH  Offline
Then x by height -
David Vizard says you need to adjust the height of the filter to account for the top & bottom molding and edge effects. So, your 3" filter calc really should be more like 2-3/4" (or whatever a particular filter measures) when you're trying to come up w/ effective surface area.
Also, for those who question the data I found and posted from tests performed elsewhere, no problem. But if you feel the need to pi$$ on the results, you should probably dig up your own data or -- even better -- conduct your own tests to (in)validate it.
At least I took the time to try and find something more than just a bunch of opinions on the subject.
Re: Air filters on race cars?? [Re: BradH] #1715223
01/06/15 01:34 PM
01/06/15 01:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Then x by height -
Hey Brad........."what" you really need to eat a Snickers........"why" because you`re not yourself when you don`t........ and, I used to wake up EVERY single day pissed off and ready to kill but I found internal peace and my Chi is looken better also. CHILL..........you have great info and I APPRECIATE IT BRAD.................
Re: Air filters on race cars?? [Re: Thumperdart] #1715224
01/06/15 02:24 PM
01/06/15 02:24 PM
BradH Offline
BradH  Offline
I'll have to settle for a blueberry muffin and a large hot chocolate. It's a little snowy here today and the forecast for the rest of the week isn't showing much break in the temp, either.
