windshield leaking jeep cherokee #1714839
12/24/14 01:39 AM
12/24/14 01:39 AM
Jefferson State
srt Offline OP
ESYC
srt  Offline OP
ESYC
Jefferson State
I had a shop replace the cracked windshield on our jeep. After several days outside in the rain I found over a gallon of water on the front and rear floor of the passenger side. I pulled trim and seats and have vacuumed, propped up and have been drying the carpet and sound deadening for two days. The rag insulation is still dripping wet, but getting better.
I decided to pull out the rubber bezel (trim) on the exterior side. This it the type that the glass sets on sealant and the trim (bezel)is set into the window sealant to basically cover the sealant and edge of glass. The bond was easy to break as it's been in only a couple weeks.
On the lower edge of the windshield I found a spot where the glass was not making contact with the glass, a strip about an inch wide at one part, 1/8" at the other.
Can this be successfully (and properly) sealed up without pulling the glass, or does it have to come out?
Also, should the trough at the bottom of the windshield be open to allow water to drain toward the fenders.
There seems to be a couple areas the sealant is creating dams that may be holding water at the bottom of the windshield and behind the rubber trim (bezel).
I don't know if I should go along with a patch, or ask for r&r.
Re: windshield leaking jeep cherokee [Re: srt] #1714840
12/24/14 02:01 AM
12/24/14 02:01 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
major problem on cherokees.best to take glass out and start over
Re: windshield leaking jeep cherokee [Re: d-150] #1714841
12/24/14 02:24 AM
12/24/14 02:24 AM
Jefferson State
srt Offline OP
ESYC
srt  Offline OP
ESYC
Jefferson State
that is what I figured. needed enough guidance as what they told me on the phone sounded hokey. I can't see how they can get the seal groove back around the glass and insure a proper seal to the poly. Trying to get poly into the small area where the glass is not bonded also seems problematic. I imagined they might try to jerry-rig-it somehow.
Re: windshield leaking jeep cherokee [Re: srt] #1714842
12/25/14 02:23 AM
12/25/14 02:23 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
If you pulled the the outside molding off the glass the only good way to reattach is to r&r.
Re: windshield leaking jeep cherokee [Re: srt] #1714843
12/25/14 07:40 PM
12/25/14 07:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What year and model Cherokee?
