Re: READING A CAM
[Re: polyspheric]
#1714570
12/23/14 02:21 PM
12/23/14 02:21 PM
Quicktree
its for a SB
To do what?
was thinking the same thing
Re: READING A CAM
[Re: MIKES_DUSTER]
#1714571
12/23/14 02:33 PM
12/23/14 02:33 PM
Posts: 3,916 usa
lewtot184
usa
Ultradyne solid roller. .556/.556 , .285/.295 , .249/.259 @ 50. Is there anything that you can tell me about this cam??? Good,bad,ugly???? Oh yeah, its for a SB.
not radical (i hate radical cams), should be easy on parts and shouldn't need a lot of spring. probably make a reasonable street roller; if the lsa isn't too tight.
Re: READING A CAM
[Re: MIKES_DUSTER]
#1714573
12/23/14 05:00 PM
12/23/14 05:00 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
What lobe seperation angle is the cam groud on?If it is ground for NOS, 110 to 114 pass on it unless your wanting to run a NOS(spray) cam , if ground for N/A on 104 to 108 LSA it will probally work well for that application ![](/ubbthreads/images/graemlins/Twocents.gif)
