magnum wheels wiwood brakes #1714140
12/22/14 06:28 PM
12/22/14 06:28 PM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
I sent Wilwood the measurements for my 15" Magnum wheels ,which the inside measurement is 145/8" and from the stud hole to the rim is 5 1/2".the kit that I am thinking about buying is P/N 140-11020
http://www.wilwood.com/Images/BrakeKits/WCD_Drawings/WCD_dwg-Large/ds757_wcd-lg.jpg
Any opinion and help if this kit will fit with the Magnum 500 wheels would be a great help.
Also is there any other measurements I should be looking at.
Re: magnum wheels wiwood brakes [Re: 1967GTX440] #1714141
12/24/14 01:31 PM
12/24/14 01:31 PM
Ontario,Canada
Ontario,Canada
BTT Wow nobody got any info
Re: magnum wheels wiwood brakes [Re: 1967GTX440] #1714142
12/24/14 01:39 PM
12/24/14 01:39 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Just want to tell you that Wilwood customer service is pathetic including their technical knowledge (can't say what I really want to on this board). I have Wilwoods on the race car front and rear and never again for me. Anyone but Wilwood...........
Re: magnum wheels wiwood brakes [Re: markz528] #1714143
12/24/14 02:36 PM
12/24/14 02:36 PM
MD
p d'ro Offline
p d'ro  Offline
MD
Can't help. I have magnum 500s under the Master Power Brake rotors. Had stock discs but switched em out. The probably have a skeleton holiday crew.
Re: magnum wheels wiwood brakes [Re: 1967GTX440] #1714144
12/24/14 04:19 PM
12/24/14 04:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have an older kit, 140-2721-B. Size and clearance wise, it might the same as the kit you are interested in (10.75" rotor, .810" thick). Mine fit the conventional 14" Ford rims I have, but not a 14" Chrysler rim. The sales guy was no help and provided mis-information too.
Because I knew I was close, I made a fixture from their cross-section information available on line. Made the fixture, and fitted it to the rims before I bought them. I can send you a picture if you want.
