Where is the 4 spd reverse light wire hole@firewall #1713516
12/21/14 01:17 PM
12/21/14 01:17 PM
USA
l13 Offline OP
l13  Offline OP
USA
Is there a dedicated hole on the firewall for the wire from the 4 speed trans to fuse block then to the reverse light inside the car on the lower dash for a 1970 Challenger? If so where is the hole located and what is the diameter?
Re: Where is the 4 spd reverse light wire hole@firewall [Re: l13] #1713517
12/21/14 02:57 PM
12/21/14 02:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not sure but i would think it would be tied into the backup light wiring in the bulkhead connector.
Re: Where is the 4 spd reverse light wire hole@firewall [Re: cudaman1969] #1713518
12/21/14 03:43 PM
12/21/14 03:43 PM
BDW Online content
BDW  Online Content
Re: Where is the 4 spd reverse light wire hole@firewall [Re: BDW] #1713519
12/21/14 10:56 PM
12/21/14 10:56 PM
USA
l13 Offline OP
l13  Offline OP
USA
Thank you for the photo depicting the correct location for the reverse light. That helps a lot.
