1966 Charger Strip/Street Car Build Thread
#1713368
12/20/14 11:22 PM
12/20/14 11:22 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
As some of you know we picked up Chris Johnston's back '66 Charger a few months back. This thread is going to help consolidate my various questions as we go along. Basic drive train stats: Engine: 4.375" bore 400 block 4.25" stroke 4340 crank 6.535" h-beams -12.5cc Diamond pistons with H13 pins (10.8 sCR) Hughes CNC ported Edelbrock MW heads Jones custom roller 1.7 ratio rocker arms Indy tunnel ram (2) HVH 4150 to 4500 adapters (2) 1050-AN 4150 QF carbs Trans: Lenco ST-1200 4-speed 10.5" two-disc indestructible clutch Rear Suspension: Dana w/ 4.56's Strange axles Ladder bars with coil overs (provisions for in-board leaf springs as well) unknown non-adjustable shocks Front Suspension: Stock, in need of serious rebuild 16:1 manual steering box coming soon Body: Shooting for around 3000 lbs with a 16 gallon fuel cell, two seats and license plates. We are finally to the point of mocking things up to get the shifter position to they guys at Lenco and fabbing up the slide rails for it to rest on. If you see anything in the pics that could be done better or smarter please don't be afraid to chime in. I sure could use the advice.
Re: 1966 Charger Strip/Street Car Build Thread
[Re: Jeremiah]
#1713370
12/21/14 06:53 AM
12/21/14 06:53 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
Looking good Jeremiah! Will be following your progress with interest! Run it on E85 and you can pick up some free extra horses
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
[Re: Swedcharger67]
#1713371
12/21/14 02:18 PM
12/21/14 02:18 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
What? I do not recall Chris mentioning in any of his adds that he had paper on the car. Dang it! Would love to see that thing terrorizing public streets...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1713372
12/21/14 03:48 PM
12/21/14 03:48 PM
Jeremiah
Rogue River, OR
[Re: Jeremiah]
#1713375
12/22/14 01:21 AM
12/22/14 01:21 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The motor plate in the car has the engine tilted 3 degrees rearward (with lots of weight missing on the front end). Is this a good starting point or should I shoot for 5 degrees?
It will effect where the pinion angle will be set. Ron
[Re: Jeremiah]
#1713385
12/22/14 04:40 PM
12/22/14 04:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That is a very good point Ron. I'll measure the pinion angle at the differential yoke and report back.
Anybody have an opinion on how the pinion angle should be set in a car with ladder bars and coil overs?
Now on to the next mock up hurdle. The Enderle tunnel ram linkage does not quite fit my Indy manifold. The spacer that bolts to the center intake bolts leaves the throttle pivot too far inboard. I think the easiest way to handle this is move the bracket out and ditch the spacer. I'll let the pictures illustrate.
For your engine placement point the C/L of the engine trans right at the pinion so its all in line with zero pinion at this time... then roll the pinion down 2* for your ladder bar.... I use a laser pointer in a block that mounts into the rear main but that wouldnt help you out... I need to make one up that mounts on the trans trailshaft so it would show you where its at on the pinion
[Re: MR_P_BODY]
#1713386
12/22/14 05:43 PM
12/22/14 05:43 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Nice car. I like that body style, color, and wheel choice.
67' charger 499 RB
10.57 at 127
