Problem at the machine shop #1713032
12/20/14 02:43 AM
12/20/14 02:43 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Had a 73 340 sitting in corner of garage and picked up a 80 step side 2wd. Tore down the engine 2 cylinders bad . Took everything to machine shop.Needs bored crank turned rods balanced.So I order .060 over pistons and get a call the pistons are out of the block .100. well that won't work.I ordered Kieth Black pistons. Deck height is 9.538. need ideas. this was to be a cheep build ha ha.
Re: Problem at the machine shop [Re: rickb67] #1713033
12/20/14 03:23 AM
12/20/14 03:23 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Are you sure they shipped you the correct CH piston?
If the deck was stock at 9.60 you would still be .038" positive.
Kevin
Re: Problem at the machine shop [Re: Twostick] #1713034
12/20/14 05:00 AM
12/20/14 05:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
buy 72-73 340 pistons, there compression height is .100 less then the 68-71 340 piston.
Tony
70 AARCuda Vitamin C
Re: Problem at the machine shop [Re: 70AARcuda] #1713035
12/20/14 09:29 AM
12/20/14 09:29 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Sounds like you have a 360 stroke crank with a 340 compression height piston.
A 340 with standard ch pistons should not stick out .100 on a 9.53 block. That is only .050" shorter than stock.
What is the CH on the new pistons? 3.31 stroke divide by 2, 1.655". Add that to your rod length, should be 6.123", 7.778". Subtract this number from you deck height. That will be the tallest ch you can use.
Re: Problem at the machine shop [Re: Leon441] #1713036
12/20/14 01:11 PM
12/20/14 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't know what the deck height on a 340 block is supposed to be but you better step back for a moment and think. If the block has been decked a lot how is an intake going to fit ?
Re: Problem at the machine shop [Re: JohnRR] #1713037
12/20/14 02:28 PM
12/20/14 02:28 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Weren't the stock 68-71 pistons positive deck? +.020 or so IIRC
Leave the gun.......take the Cannoli's....Mike
Re: Problem at the machine shop [Re: 70AARcuda] #1713038
12/20/14 02:34 PM
12/20/14 02:34 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
It has been along time since I built a 340, but if I remember correctly the 68-71 340 piston had a stock positive deck height of .045. If you block has been decked down to 9.538 then it is approx .062 shorter than stock which would make the 68-71 piston stick approx .107 out of the hole. My figures may be off slightly but if you put the 72-73 piston in which is .100 shorter you should be near a zero deck.
Re: Problem at the machine shop [Re: dragnduster] #1713039
12/20/14 06:36 PM
12/20/14 06:36 PM
florida/ Georgia
Tom Fox Offline
Tom Fox  Offline
florida/ Georgia
Most recent 340 I've built,(last week)the KB 243 pistons were out of the hole .024. the block was parralel decked, & I beleive my machinest said about .006 ?
Re: Problem at the machine shop [Re: Tom Fox] #1713040
12/21/14 12:40 AM
12/21/14 12:40 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Just did a 340. Slight clean up of decks resulted in Speed Pro hyper pistons being .050 out of the deck.
Since the heads are RHS with a 62 chamber, we sliced .050 off to get to zero deck. This way owner can run a standard Fel Pro head gasket and have .038 piston to head clearence vs. a MLS type gasket.
Re: Problem at the machine shop [Re: rickb67] #1713041
12/21/14 01:56 AM
12/21/14 01:56 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
What was the compression height of the old pistons?
Without Data, you’re just another guy with an opinion.
Re: Problem at the machine shop [Re: rickb67] #1713042
12/21/14 02:09 PM
12/21/14 02:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
what machine shop? I've had B&M do 3 engines and they all worked very well.
Re: Problem at the machine shop [Re: sr4440] #1713043
12/21/14 02:12 PM
12/21/14 02:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
just use a thicker head gasket(multiple layer gaskets can go up to 1/4 inch) deck height will be back where the intake fits.
Re: Problem at the machine shop [Re: cudaman1969] #1713044
12/21/14 02:23 PM
12/21/14 02:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you could probably buy a new block for what it would cost
Re: Problem at the machine shop [Re: Quicktree] #1713045
12/21/14 02:35 PM
12/21/14 02:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
about the price of those new pistons
Re: Problem at the machine shop [Re: sr4440] #1713046
12/21/14 08:10 PM
12/21/14 08:10 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
We had run the engine a few years back in sons Duster. He got a 360 for the Duster and the 340 sat in the corner. Pistons were the 8.5 73 pistons i think they were .020 down the whole. I guess I need 73 style .060 pistons.
Re: Problem at the machine shop [Re: rickb67] #1713047
12/21/14 08:50 PM
12/21/14 08:50 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Pistons + lathe + 1 hour = fixed
Re: Problem at the machine shop [Re: TRENDZ] #1713048
12/24/14 01:36 AM
12/24/14 01:36 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Sounds like I can solve my problem with 72-73 pistons like the L2385 pistons but i need .060 over and am not having any luck. Anybody have an idea on where to get them.
Re: Problem at the machine shop [Re: rickb67] #1713049
12/24/14 02:26 AM
12/24/14 02:26 AM
smyrna,tn
draginmopars Offline
smyrna,tn
Hypereutectic-Compression Distance (in):1.840 in.
http://www.summitracing.com/parts/uem-skb243l-060/overview/
Sealed Power Cast Pistons- 1.829
http://www.summitracing.com/parts/slp-428p60/overview/
D.S.S. GSX-Series Forged Pistons
Compression Distance (in):1.457 in.
http://www.summitracing.com/parts/dms-6405x-100/overview/
Keith Black KB Performance Pistons
Hypereutectic aluminum-Compression Distance (in):1.840 in.
http://www.summitracing.com/parts/uem-kb243-060/overview/
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
