Re: 1500 Ram Truck recall coming in Feburary.
[Re: Challenger 1]
#1712697
12/20/14 07:49 PM
12/20/14 07:49 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
I wish they'd recall the 2012 model Ram's....the headlights are SCARY bad....I won't even drive my truck at night time unless I have to....
luckily the 2012 Ram 1500 I have is a company truck, if it was mine I would have already returned it and told them where to stick it.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: J_BODY]
#1712699
12/21/14 08:47 PM
12/21/14 08:47 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
I adjusted the lights on my '11 higher.. Huge difference.. Then I added a 2" level kit up front and had to readjust..lol..I had the pinion nut recall done a year and a half ago.. But I did hear of some bad stories when the nut fails to hold torque.
When you decide to quit, THAT is the moment when you would've succeeded..
[Re: shanker]
#1712701
01/09/15 08:07 PM
01/09/15 08:07 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Huh, I bought my Ram 1500 4x4 in January of 2005. So, mine should be on this recall list. That's great. When should I expect a letter?
Rear pinion seal leaks a little too, but I've never worried about that.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: shanker]
#1712702
01/19/15 06:21 PM
01/19/15 06:21 PM
Posts: 35 Northern NJ
67440dodge
Northern NJ
Same complaint with the 2012 Tradesman I had. First indication I had Bambi's mom was in the road was when the airbags deployed.
I made sure when I test drove the 2014 Tradesman I did it at night. Major difference. Think they went to a 4 bulb setup over the 2 bulb in the '12's.
[Re: hemi70se]
#1712704
01/23/15 10:28 PM
01/23/15 10:28 PM
67440dodge
Northern NJ
That is not some change they made in a certain year, you are just comparing the STANDARD headlights against the OPTIONAL quad headlights.
My 2012 Tradesman with STANDARD headlights had 2 bulbs in it.
My 2014 Tradesman with STANDARD headlights has 4 bulbs in it.
Pretty solid comparison I think..
[Re: shanker]
#1712705
01/25/15 02:35 AM
01/25/15 02:35 AM
Posts: 657 B.C.
mk_
B.C.
I've worked on several 2012 and 2013 rams with headlight complaints and found the original philips headlight bulbs had black soot on the inside of the glass…….some so bad you could hardly see the filament when the trucks were 6 months old! Changed them to sylvania ultra's and it made a big difference.
