Master cylinder studs #1711741
12/16/14 11:52 PM
12/16/14 11:52 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
I have a 70 RR with manual disc brakes. My question is are there two different size studs that press into the housing of the cylinder? My studs splines are to small for cylinder. I have another set of the studs that are to big.
Re: Master cylinder studs [Re: stateroadhog] #1711742
12/17/14 12:58 AM
12/17/14 12:58 AM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
I used the small ones and picked up some brass shim stock at ACE Hardware. Wrapped them with a little shim stock and pressed them in. Good and tight fit. Good luck!!
