GG1 paint formula for sherwin Williams? #1711673
12/16/14 08:52 PM
12/16/14 08:52 PM
Elk Grove, CA
challngr08 Offline OP
Elk Grove, CA
Guys the painter I use is painting my 68 using sherwin Williams and we can't find a formula for gg1 racing green. Anyone know a formula by them? Ppg lists a 43649 I believe it is but we cannot find a cross. Any help is appreciated. Thanks
Re: GG1 paint formula for sherwin Williams? [Re: challngr08] #1711674
12/17/14 01:23 AM
12/17/14 01:23 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
will this work?
Re: GG1 paint formula for sherwin Williams? [Re: challngr08] #1711675
12/17/14 07:42 AM
12/17/14 07:42 AM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
If he can get ahold of a paint rep through his jobber they might be able to put together a formula if they have a piece to analyze. I'm not sure if SW has the ability to digitize the colors like ppg or dupont. Years ago our paint rep would run off with part and a week later have the part, a sample, and a formula. Not all paint maufactures kept up with the old formulas as the lead based and heavy metals were removed from toners, and paint systems were updated.
If all else fails and If he's worth his weight, pick something close, tint, and record the numbers if he's really stuck on the SW.
I recommend staying within one line but PPG base is really stable/non-reactive and I have covered it with many different clears without issue(never tried with SW though). Just seemed an extremely slow cure time on the SW clears that I have used.
Re: GG1 paint formula for sherwin Williams? [Re: 6bblgt] #1711676
12/17/14 11:04 PM
12/17/14 11:04 PM
Elk Grove, CA
Elk Grove, CA
Thanks! He found it in ppg and I matched it with a section on windshield frame that was untouched for past 45 years and looks new . Spot on!
Re: GG1 paint formula for sherwin Williams? [Re: challngr08] #1711677
12/17/14 11:06 PM
12/17/14 11:06 PM
Elk Grove, CA
Elk Grove, CA
Thanks for the paint chip as well. They only can find gg1 in 1966 through sherwin Williams so he is just going to spray in ppg since the match is awesome.
