QA1 tubular K-Members - anyone using one?
#1711307
12/16/14 01:43 AM
12/16/14 01:43 AM
Posts: 220 Aurora, CO
jbeintherockies
Aurora, CO
Hello, My brother is considering going with a QA1 tubular K-member in his 1967 Belvedere II with a big block and 4spd. Is there anyone on here running one on the street? If so, what do you think? Is it worth the $600 bucks? Is it strong enough for street use? http://chucker54.stores.yahoo.net/qa1motuk2.html#.VI-oxHshWM8Thank you in advance.
Re: QA1 tubular K-Members - anyone using one?
[Re: jbeintherockies]
#1711308
12/16/14 01:53 AM
12/16/14 01:53 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.jegs.com/i/QA1/122/52315/10002/-1Dont know if they worth it..but this is 15 dollars cheaper plus free shipping.. I have one on a 71 dart but it is a bracket racer not a daily driver.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: TC@HP2]
#1711311
12/16/14 06:42 PM
12/16/14 06:42 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I wonder if they make them with Hemi mounts? Never looked but they do seem to add a lot of room over a stock K frame
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: TC@HP2]
#1711313
12/23/14 03:16 PM
12/23/14 03:16 PM
jbeintherockies
Aurora, CO
I just got off of the phone with QA1 tech support. He told me the new B/E body tubular k-member is designed to use the factory torsion bars. In order to use coil overs with their tubular k-member, custom fabrication would be required.
I also asked how much they weigh and he told me about 35 pounds.
Just passing that along.
#1711317
12/24/14 12:46 PM
12/24/14 12:46 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Several potential issues, at least on the A-body version I studied:
> Tension-strut bushings mounts are just cantilevered tabs welded on. Welds probably will not fail, but tubing will tear. Stock Ks had several generations of beefing and re-beefing to prevent this common problem (bushing would actually tear thru the K).
> Lack of diagonal gusseting (and short distance between the cross-tubes) is a worry -- it can basically "parallelogram"
> Biggest issue: Cannot use stock "locator" attaching bolts, in fact, 2 holes are slotted...remember, tying the chassis rails together is the primary purpose of the K-member!
Would be fine on a drag car, fine as glass-pavement cruiser; I'd not use it on potholed streets, Auto-X, etc.
Rick
[Re: Rick_Ehrenberg]
#1711318
12/24/14 01:02 PM
12/24/14 01:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Rick
Don't go over to the street rod forum and tell them any of this, see Custom 33 thread.
#1711319
12/24/14 06:10 PM
12/24/14 06:10 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
https://www.youtube.com/watch?v=ydy-I62cnj8This video is my car. QA1 borrowed it and had it at their facility all last winter test fitting all possible OEM/QA1 component combinations and trying them all out. I'd posted a few photos of the work here last winter. https://www.youtube.com/watch?v=-aU4kxeziEcHere's a shorter video on the control arms, etc. Last April they let me know they were done with the car. I drove it around all last summer. I was pleased with the setup. Car handles well and in my opinion is plenty strong for street use. The system looks hi tech and really cleaned up the engine compartment.
Lead, follow or get the hell out of the way
#1711320
12/24/14 11:54 PM
12/24/14 11:54 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I believe QA1 bought out CAP inventory, engineering docs. and the right to sell them under thier name. That being said I had bought second hand one NOS NIB of CAP K members for a early, 1963 to 1966 A body to use in my 1965 Dart bracket car to eliminate the stock steering and torsion bars, when I got it it was for a stock replacement application I contacetd Ray at CAP and he said he would change it so I could use the front rack and pinion as well as coil overs on the front to get more clearances for headers using a BB in that car. I ended up selling that K member to Mopar Billy, it is in his 1962 A body drag week car I beleive, has been for several years. Hopefully he will chime in here and let us know what he thinks of it now
#1711321
12/25/14 05:35 AM
12/25/14 05:35 AM
Posts: 797 WA
pro451bee
WA
