68 Runner Radio Delete plate #1711272
12/16/14 12:59 AM
12/16/14 12:59 AM
SC304 Offline OP
SC304  Offline OP
Can anyone tell me if there is a Delete plate for the Radio available?
Thanks in Advance
Mike
Re: 68 Runner Radio Delete plate [Re: SC304] #1711273
12/16/14 01:21 AM
12/16/14 01:21 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Ask this seller.
http://www.ebay.com/itm/1965-PLYMOUTH-BE...=p2047675.l2557
He does reproductions and would know the answer.
Re: 68 Runner Radio Delete plate [Re: John Brown] #1711274
12/16/14 11:25 PM
12/16/14 11:25 PM
SC304 Offline OP
SC304  Offline OP
Thank you
Re: 68 Runner Radio Delete plate [Re: SC304] #1711275
12/17/14 01:13 AM
12/17/14 01:13 AM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
Thanks in Advance
Mike
GCARTRIM.com
He may be able to help you.
Re: 68 Runner Radio Delete plate [Re: SC304] #1711276
12/19/14 07:23 PM
12/19/14 07:23 PM
CrazyD Offline
CrazyD  Offline
Anyone know if the 68/69 Roadrunner radio delete plate is perfectly flat, or does it have a slight 'V' in the middle?
Re: 68 Runner Radio Delete plate [Re: CrazyD] #1711277
12/20/14 01:15 PM
12/20/14 01:15 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'm pretty sure there is a contour to the plate , it would have the same contours as a radio plate with the cutouts , the hole is still in the dash , the dash frame isn't any different for a car ordered without a radio.
Re: 68 Runner Radio Delete plate [Re: JohnRR] #1711278
12/20/14 01:18 PM
12/20/14 01:18 PM
CrazyD Offline
CrazyD  Offline
thanks John, I thought maybe it was warped, but it does seem to have same contours as the radio faceplate in my car.
