Page 3 of 4 1 2 3 4
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711038
12/18/14 06:17 PM
12/18/14 06:17 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That sheet is VERY important! Dont let anything happen to it!
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: ScottSmith_Harms] #1711039
12/18/14 06:46 PM
12/18/14 06:46 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
You are lucky that broadcast sheet is under the seat. That's a wonderful Christmas present! Did your Cuda come factory equipped with rear window louvers? That is going to be one sexy car when finished.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: FJR doc] #1711040
12/18/14 07:22 PM
12/18/14 07:22 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
I took few pictures but it`s hard to read it. I have to get it from the seat first to decode.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711041
12/18/14 10:31 PM
12/18/14 10:31 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Very, very carefully they can be fragile. Hopefully it is the one from your car.
Careful, your character's showing!
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: mopar346] #1711042
12/19/14 12:53 PM
12/19/14 12:53 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Unless you have 3 hands, have a helper lift the springs so you can carefully remove the sheet.
Have you posted your missing 340 number in the lost and found here.
You never know...
Looks to have the textured rear window moldings as well.
BTW ..thats just a really cool 71 Cuda
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: mccannix] #1711043
12/19/14 03:17 PM
12/19/14 03:17 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
I hope the sheet will survive and will be readible. My cuda has manual steering, was that common? How is it to drive it?
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711044
12/19/14 05:40 PM
12/19/14 05:40 PM
P
PasiR Offline
PasiR  Offline
P
I liked a lot manual steering I had on my 383 Cuda.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711045
12/20/14 08:46 PM
12/20/14 08:46 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
It was a good day today. I spent it digging the broadcast sheet out off the seat, and it went quite well. Almost all numbers are readable and I did decode it, here is my Cuda specification:
1971 Plymouth Cuda 340 4sp
carline body type en year plant
BS 23 H 1 B
Trim code UDF color Paint style Body paint
H6XV 000 V01 EV2
Interior color: H6XV orange
Body paint: EV2 - tor red/hemi orange
Engine: H - 340 V8
Trans: D23 HD 4spd man
Axle: D53 D91 3.23:1 Suregrip
C55 Bucket seats
C93 Carpeting
B11 HD drum br E bdy
A45 Spoiler pkg-frt&rear
A62 Rallye Instru. Clustr
A67 Plymouth Backlight louver pkg
G36 O/Sduel pnt race mir
G41 I/S day/nite mirror
F23 59 a/h 375 cca bat
F56 Anti freeze
F96 oil-press/temp Gge.
J15 cig lighter
J21 elec clock
J25 3spd var wipers
J31 single horn
J45 hoodpins w/lanyards
J68 rear wind louvers
J81 Rspoiler wing typ 70-2
M25 wide sill mold
M26 wheel lip mold
M31 belt&hood mold
M88 1/4panl tape treatment
L75 low fuel Lmp
L76 warning gauges
N31 opt compress ratio
N42 crome duel exhst tips
N65 7-blade clutch dr/fan
N85 tach
R11 music master radio am
S13 ralleye susp w/sway bar
S25 HD/firm ride shock absb
S41 rear sway bar
S81 sim wood steer wheel
W21 rally wheels 70/71
Is there anything special or rare about thic car?
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711046
12/20/14 09:17 PM
12/20/14 09:17 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
ABSOLUTELY Special
340/4speed
Great Color/Cool Interior/rallye gauges/vinyl top/louvers/spoilers....
This is a great 'Cuda, find a good 340 block and bring her back to life
I love it.
1971 BS23H1B
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711047
12/20/14 09:25 PM
12/20/14 09:25 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Well I'm no E body guy but it looks like it has a few more options checked off than most other cudas left the factory with. They are all rare, but still its the big blocks shakers that command the big $$$
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: ademon] #1711048
12/20/14 09:48 PM
12/20/14 09:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nicely equipped car!
M88 is not rear tape stripe (common mistake with online decoders). It's actually the Cuda rear tail lamp panel surround stainless.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: ScottSmith_Harms] #1711049
12/20/14 10:27 PM
12/20/14 10:27 PM
mopar346 Offline
mopar346  Offline
That is a really cool car, the way it is decked out it's kinda surprising that they didn't check off power steering and power disc brakes. No matter, I would rahter have the options they DID check off.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: mopar346] #1711050
12/21/14 02:54 AM
12/21/14 02:54 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Do you happen to know the SPD build date on the fender tag or broadcast sheet.
1971 HEMI E BODY REGISTRY
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711051
12/22/14 07:48 PM
12/22/14 07:48 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
Broadcast sheet straightened, put together and laminated. Result seems to be nice in comparison to how it looked in the seat.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: terzmo] #1711052
12/22/14 08:59 PM
12/22/14 08:59 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
another 340 is the answer...hell of a better motor than a 360
Not
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: StrkrDart69] #1711053
12/22/14 09:04 PM
12/22/14 09:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I was going to post "Dont laminate the sheet!" But I guess Im too late. Be sure to make several high resoloution scans now, sometimes the inks can fade or run when sealed into the plastic like that.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: ScottSmith_Harms] #1711054
12/22/14 09:12 PM
12/22/14 09:12 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
I did scan it. There was not that many options, it was torn into many pieces, you couldn`t touch it or move it. No numbers dissapeared, looks more bright and sharp than before. I don`t expect it should react after it was laminated.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711055
12/22/14 09:27 PM
12/22/14 09:27 PM
mopar346 Offline
mopar346  Offline
It's done now so hopefully it will be preserved. I put mine in plastic sleeves.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: mopar346] #1711056
02/25/15 05:24 PM
02/25/15 05:24 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
I have no idea, why I cannot start posts in swap forum and parts wanted forum, i will try it here. Looking for following parts for my cuda:
1. rally dash instrument gauge
2. left and right door and quarter window - tinted
Any offers, please PM
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711057
02/25/15 05:40 PM
02/25/15 05:40 PM
dogdays Offline
dogdays  Offline
In the for sale section you just "reply" to the last post. Put your own title in it, though.
R.
Page 3 of 4 1 2 3 4
