Page 1 of 4 1 2 3 4
71 cuda - 340 lost, what`s the best replacement? #1710998
12/15/14 04:53 PM
12/15/14 04:53 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
I recently bought 71 cuda, originally 340 (unfortunattely lost 20+ years ago), not running since. It is 4 speed car, transmission still there. Because of 340 engines are expensive (12k for crate engine), I`m considering to use 408 stroker (360) engine instead, which are around 7k, and they shoudl have more HP. It is my first E-body, have no experience, so here are my questions?
1. will 360 (408) fit without any frame adjustments or adapters to 340 car?
2. will it fit to original 4 speed?
3. any recommendation, where to buy 408 (engine builders, etc...- I found it on Summit and Ebay from ATK)
4. in general, is it smart to use this type of engine? Or would you recommed something totally different?
The reason why I want to keep it small block is because of weight and easy handling.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1710999
12/15/14 05:08 PM
12/15/14 05:08 PM
GA
roadrunninMark Offline
GA
If you want to find an inexpensive engine, I would go with a 360 magnum from a truck/dakota. If you have a decent budget, I would go with Gen 3 Hemi and transmission. If you can buy a wreck in your country to transplant everything, that would save you quite a bit of money. A Gen 3 hemi will get you quite a bit of power for the buck plus mileage.
Welcome to the board. Please start a post with your build and post lots of pictures!
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711000
12/15/14 06:24 PM
12/15/14 06:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes the 360/408 will bolt right in and it will fit the 4 speed. I would not go to Summit or Ebay to buy a crate motor.
Gen 3 hemi would be a great idea but it's not going to be a direct bolt in .
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: roadrunninMark] #1711001
12/15/14 07:06 PM
12/15/14 07:06 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
At the moment I`m in process of gathering info about E-body, checking what is missing in my car, what I have to buy etc.
I would like to keep original 4 speed and I found in article in HotRod magazine, nobody ever have tried to use gen 3 hemi with this transmission (don`t know why).
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711002
12/15/14 07:13 PM
12/15/14 07:13 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
"best" is subjective and depends on your needs/wants/useage and how close to stock you intend the car to be.
I have zero interest in having a modern hemi in a classic car, so "best" for me would be a 340, followed closely by a 360 (likely stroked).
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711003
12/15/14 07:26 PM
12/15/14 07:26 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Welcome to the board, Delta.
You have all the right ideas. The Edelbrock aluminum heads would also compliment your goal to keep it light.
For point of reference, running 360's can be had around here for $1000.00 or less, and complete re-build candidates can be had in the $500.00 range. Now, factor your shipping costs plus the cost of re-build and see if that becomes a viable option to source one from here and have it sent to you.
Mo' Farts
Moderated by "tbagger".
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: DPelletier] #1711004
12/15/14 07:56 PM
12/15/14 07:56 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
That`s exactly, where I am now. To decide, which direction to go. Generally I prefer original cars, but since original engine is gone and it will never be numbers matching, I have more choices. But I tend to have it with small block now.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711005
12/15/14 08:15 PM
12/15/14 08:15 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
You might have a balance problem with the 360. They are externally balanced. You need to know if your current flywheel is for an internal or external balanced engine. If internal. Then use a 318 block and a 4" stroke crank. But on second thought. It might require either combo to be internally balanced.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: rt66jim] #1711006
12/15/14 08:23 PM
12/15/14 08:23 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
A Mopar 360 cast flywheel is commonly available.........see below,
http://www.ebay.com/itm/FLYWHEEL-CAST-19...05e&vxp=mtr
Personally, I'd do the 360/408 stroker. Minimal fuss with maximum fun.
At $12k for a crate motor you could call MuscleMotors and they could custom build you an engine to your spec's. I know they'll ship overseas.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711007
12/15/14 08:23 PM
12/15/14 08:23 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
another 340 is the answer...hell of a better motor than a 360
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711008
12/15/14 08:26 PM
12/15/14 08:26 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I see orange '71 'Cuda & seats - spoilers & louvers - you mentioned that it's a 340 4-spd car. Likely the top of the 340 food-chain short of a convertible - can you share fender tag info?
An iron headed 360/408 can be dressed to appear as stock as an original 340.
Its impact on your wallet will be minimal,
and its negative impact value/desirability of the 'Cuda would be minimal.
sounds like a WIN-WIN!
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: terzmo] #1711009
12/15/14 08:31 PM
12/15/14 08:31 PM
Central TX
roe Offline
roe  Offline
Central TX
If built the same,part for part, the 360 would be the stronger of the two right? Unless the larger bore size of the 340 would make a huge difference.
And when both get a 4" crank then you'd have a 408 and a 416 that should run pretty evenly. If thats true then the 360 woukd look better to me simply because of the lower initial purchase price.
Add in the ability to go magnum based stroker with the better heads and roller cam (no worry of wiped lobes), then I'd really lean 360.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: 6bblgt] #1711010
12/15/14 08:32 PM
12/15/14 08:32 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
IMO I would for sure go with a 340 replacement or at least a small block made to look pretty close to original. Looks like you have a very nice 71 340 cuda and there is nothing cheap about one of those.
No way I would go with a new model hemi. Great looking car and best of luck.
Matt
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: 6bblgt] #1711011
12/15/14 08:37 PM
12/15/14 08:37 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
another vote 360 magnum,put some eq magnum heads stock look,roller cam
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: d-150] #1711012
12/15/14 09:19 PM
12/15/14 09:19 PM
france
jose jones Offline
jose jones  Offline
france
the Gen 3 motor requires some extra work, since you are in Europe parts might be more difficult to obtain, my vote... 360 that is stroked looks like a 340 but good HP
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711013
12/15/14 09:28 PM
12/15/14 09:28 PM
dogdays Offline
dogdays  Offline
The 340 and 360 are the same engine on the outside.
The original 4-speed will mate to the 360, they were available that way when new. The bellhousing (part that goes between the engine and the transmission) is the same for both.
Make sure that you get a flywheel that matches the engine. By that I mean the flywheel will have 130 tooth ring gear, and have the normal MOPAR 6-bolt flange. But 340s and 360s had different balance. And who knows how a stroker is balanced. So, you need to make sure that WHATEVER engine you buy has a harmonic damper and a flywheel that are balanced to the particular engine you are getting.
For a clutch the flywheel will have a 10.5" pressure plate bolt pattern, and you can use the bigger clutch, they called it 10.95" to differentiate it from the larger flywheel that took either an 11" or 12" clutch. Centerforce Dual Friction would be my choice.
If you can afford aluminum heads they would help take weight off the front end, that would be good. Then also you could run 10.5:1 compression with your available pump gasoline. It should be very easy to make 500 hp with such an engine, if you want that much. If you wanted only 400hp, a 360 would do quite well.
I would suggest finding a builder on the East Coast to build an engine for you. I am suspicious of mass-produced high performance engines.
I hope someone here can give a reference or two.
Whatever you do, ask here before you buy. Or send me a pm, I love to spend other people's money.
Good Luck!
R.
The good news is that you only have to sort this out once.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: dogdays] #1711014
12/15/14 09:36 PM
12/15/14 09:36 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I agree for the most part with dogdays. Find an engine builder and spec out a zero balance 408 build (internal). Use the stock 130 tooth flywheel for a 318-340 and go.
...FAFO...
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: skicker] #1711015
12/15/14 09:49 PM
12/15/14 09:49 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
Here's the 360 in My 71 Cuda. My car had the numbers matching 340 in it and I beat on it pretty hard. So I built a 360 La 4" stroke 408. I Put my 340 on a stand in my garage. Once you use a new rotating assy. crank,rods,pistons, you can have it internally balanced so you don't have to worry about the external balance deal. Now I have no guilt beating the hell out of it and it pulls way harder.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: dogdays] #1711016
12/15/14 10:03 PM
12/15/14 10:03 PM
FL/Europe
Delta Offline OP
Delta  Offline OP
FL/Europe
Thanks all for advices! This is exactly, what I need to know. I have no problems to get all parts from US, I frequently ship containers with all the stuff here. Once the engine and all the other accessories is specified, it will be an "easy" job. I wouth rather have the engine built in US, because of much more experience. I want to get it running and make it mechanicaly like new first and enjoy driving, let the total resto for next years.
If anybody here can help me with complete specification of everything, engine builder, I would appreciate that.
PS. this is actually not my first mopar project, but my previos was rather easy, because of it was complete, all original and running, (but still it took 3 years to finish - therefore I want to drive first before deep restoration )
Good Luck!
R.
Re: 71 cuda - 340 lost, what`s the best replacement? [Re: Delta] #1711017
12/15/14 11:52 PM
12/15/14 11:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That's a rare/special car, weather you decide to install a close replacement now (or not) I would still recommend procuring the best/most accurate replacement you can find even if you keep it under the bench and decide to install something else. 1971 340's also have some one year only parts that you should also try to locate while you can (short list of larger items below).
1971 4972s Carter Thermo-Quad Carburetor
DR1114429 Idle Stop Solenoid
1970-1971 340 Air Cleaner
1970-71 Valve covers
1970-71 340 Oil Pan (294 stamped into the bottom)
1971 intake manifold- Casting # 3512100
Exhaust manifolds, casting #3418621 Drivers Side & #3418623 Passenger Side (the hard part is finding both with casting dates prior to your cars SPD)
You can learn more about correct parts details (Here ).
As far as a replacement 340 block goes your choices are pretty straight forward, most opinions will vary but the following are my personal choice list, my most to least favorite in order:
1. Find the original numbers matching block (long shot but nothing else will be 100% "correct" )
2. 340 block, warranty replacement or service block. I like these because the casting date doesn't matter so much and it won't have another cars VIN sequence number on it.
3. 340 block from another car which has an assembly date before and close to your cars scheduled production date.
4. 340 block from another 1971 model year car (any date)
5. 340 block, any year casting you can find
6. 340 block, new Mopar replacement "Resto 340" block
7. 360 block, any year
Page 1 of 4 1 2 3 4
