Mopar Create 426 465hp #1710787
12/14/14 11:48 PM
12/14/14 11:48 PM
Edmond, Oklahoma. U.S.A.
Madcoy Offline OP
Madcoy  Offline OP
I remember reading some bad things about Mopar Create motors. What's the consensus on these? I think the going prices are around $14k.
Thank for your thoughts!
Re: Mopar Create 426 465hp [Re: Madcoy] #1710788
12/15/14 12:04 AM
12/15/14 12:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Old engines done BY Cummins Recon were a crap shoot with CRAP being the big winner.
The New Crates are built by different shops now and supposed to be as advertised , ready to go . I think the 426/465 is 15k now ?
Re: Mopar Create 426 465hp [Re: JohnRR] #1710789
12/15/14 12:14 AM
12/15/14 12:14 AM
Madcoy Offline OP
Madcoy  Offline OP
I found on in a create but I wonder how I would know which builder built it? The present owner bought it within the last 2 years and has not used it.
Re: Mopar Create 426 465hp [Re: Madcoy] #1710790
12/15/14 12:20 AM
12/15/14 12:20 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
If I was to buy a Hemi crate motor, new or old, it would have to be cheap enough that I could take it to a trusted Mopar builder to be torn down and checked out.
If not, I would have a new Hemi built by a reputable shop from scratch.
Re: Mopar Create 426 465hp [Re: Madcoy] #1710791
12/15/14 12:21 AM
12/15/14 12:21 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you are looking for info on those motors online you would get better results by using the spelling CRATE motor. Create means to make, crate means packing box.
Re: Mopar Create 426 465hp [Re: stumpy] #1710792
12/15/14 12:27 AM
12/15/14 12:27 AM
Madcoy Offline OP
Madcoy  Offline OP
Yeah your right. My old eyes, big fat fingers, and auto correct can sure screw up a post.
Re: Mopar Create 426 465hp [Re: Madcoy] #1710793
12/15/14 12:30 AM
12/15/14 12:30 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I know the feeling. Old timers gets me every once in a while.
Re: Mopar Create 426 465hp [Re: stumpy] #1710794
12/15/14 02:14 AM
12/15/14 02:14 AM
chicago,il
jaque Offline
jaque  Offline
chicago,il
there are two different part numbers, i cannot remember right now, but i think the it ends in AE, the on that ends in AC AVOID.. if the motor was made at tail end of 2008 or after yopu should be good, stanton eingeneering was making them and they used the world block!!! thats the one you want!!! the current ones do not use world block, so if its a few years old odds are it has it,,,
you come here with nothing and leave here with nothing!! enjoy life while on this planet, cuz when youre dead youre dead!!!
Re: Mopar Create 426 465hp [Re: jaque] #1710795
12/15/14 02:16 AM
12/15/14 02:16 AM
chicago,il
jaque Offline
jaque  Offline
chicago,il
they came on a black stand in a big blue clam shell. 10k would be a nice price... if its taking up space in buddies garage....
Re: Mopar Create 426 465hp [Re: jaque] #1710796
12/15/14 10:49 AM
12/15/14 10:49 AM
Madcoy Offline OP
Madcoy  Offline OP
It's on a wooden crate.
Re: Mopar Create 426 465hp [Re: Madcoy] #1710797
12/15/14 01:34 PM
12/15/14 01:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the part number tag still available that would have been on the box surrounding it ? That will tell you when it was built. I don't think anything came from Cummins palletized like that. If that is a WORLD block I don't think it's a Cummins Recon motor and should be good to go , I'd at least remove the intake and have a look , rotate it over and make sure the lifters at least all spin.
EVERYONE would love to buy a 15k engine for 10k , I'll buy all that are available ...
The bad thing is any warranty the motor had is no longer any good and you are on your own, Chrysler banked on that when they sold them, most never got them installed and running within the 90 day warranty period.
I've spent a couple thousand correcting everything that was wrong with the one I bought in 2005.
Re: Mopar Create 426 465hp [Re: JohnRR] #1710798
12/15/14 01:43 PM
12/15/14 01:43 PM
dogdays Offline
dogdays  Offline
Cummins was long gone before the World block came out, IIRC.
R.
Re: Mopar Create 426 465hp [Re: dogdays] #1710799
12/15/14 02:44 PM
12/15/14 02:44 PM
Madcoy Offline OP
Madcoy  Offline OP
Is there a definite way to determine its a world block?
Re: Mopar Create 426 465hp [Re: Madcoy] #1710800
12/15/14 03:44 PM
12/15/14 03:44 PM
chicago,il
jaque Offline
jaque  Offline
chicago,il
yes by looking at the front of motor underneath the heads you will see freeze plugs covered up you cant miss them.. where the heads neet the block, looking from the front...
ill post a picture later whn i get home..
Re: Mopar Create 426 465hp [Re: jaque] #1710801
12/15/14 04:21 PM
12/15/14 04:21 PM
Madcoy Offline OP
Madcoy  Offline OP
I see freeze plugs. Can anyone tell if this is a World Block?
Re: Mopar Create 426 465hp [Re: Madcoy] #1710802
12/15/14 06:09 PM
12/15/14 06:09 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yes. The extra freeze plugs and the extra oil feed to the pump = World
