Re: Dyno vs. Dragstrip Tuning
[Re: dvw]
#1710754
12/15/14 09:15 PM
12/15/14 09:15 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Here`s the youtube video of my engine being tested http://youtu.be/9rG0doYzstEchanges at least to the timing were made for optimum power etc ........................ Same carb, ignition ,Headers were smaller (mine are 2 1/4 x 4" Hookers.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: chryco]
#1710756
12/15/14 10:22 PM
12/15/14 10:22 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I've had my Dakota on a chassis Dyno 4 times just to make sure the tune was safe and that my AF gauge was in the ball park and it wasn't going to puke oil and/or parts all over the track. Last time I got to "drive" it on the Dyno....Who cares what the results were, that's worth the price of admission right there.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: MR_P_BODY]
#1710757
12/16/14 12:40 AM
12/16/14 12:40 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I always try and use the headers that are going in the chassis and weld in the EGT bungs and O2 bung. After tuning for best timing, A/F ratio, spacers and whatnot I'll put the airflow meter on to see what the engine is actually using. Also try the aircleaner assembly they want to use, fan and alt. I've opened a few eyes by showing how bad or good some of their stuff is. My 605 LOST 117hp bolting up my 3-1/2" dual exhaust with X-pipe and 3-1/2 Ultra-Flows over open headers and collectors. A friends resto 440 mag lost 22hp using a factory dual snorkel aircleaner assembly over an open style element.Dave
There is nothing out there for exhaust on a engine of that size unless you start looking at diesel exhaust (a pair of them).. even with dyno testing I have always had to tweak it in on the track for each day if the weather is way different... the dyno tweaks it in for that day
Fair enough Mike, my dyno does have a weather station that corrects the numbers to the standard, that's about all a person can do. What most people fail to recognize is it's a tuning tool. For instance, first pull makes 400hp, after tweaking the timing, carb, intake, fuel, whatever... you might finish at 450-500hp. Doing the same testing at the strip might take a whole season or a full day or two of private testing. I made 18 dyno pulls just dialing in the thermoquads on my tunnelram. Most people can't do it but in my case I made the sacrifices and spent the money so I could.Dave
[Re: quickd100]
#1710758
12/16/14 01:52 PM
12/16/14 01:52 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
A dyno if set up right will get you close enough to where you only have to make minor adjustments at the track and get the tune perfect.Also after your engines comes off the Dyno you have enough information to send with your Torque Converter to get it set up right the 1st time.Some people say dynoing an engine is $$$ wasted,but not if you use all the information you get from it setting up your car.
PS after you dyno your engine it should only take one T&T to get everything right.Most times you can get it right doing your time trial runs and be ready to race.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1710759
12/16/14 08:55 PM
12/16/14 08:55 PM
chryco
Winnipeg ,Mb. CA.
What I wanted to hear ! Thx All ! Oh Yeah AND Merry Christmas !
