Piston/Valve clearance, how tight have you run? #1710087
12/13/14 02:21 PM
12/13/14 02:21 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
Just wondering out loud, how close have you run your piston to valve clearance and got by? I've had one 440 that had a small mechanical cam and I got by at .060 on the intake and .080 on the exhaust. That was with lash. Dave
Re: Piston/Valve clearance, how tight have you run? [Re: quickd100] #1710088
12/13/14 02:30 PM
12/13/14 02:30 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
My 6.1 is sitting at .069 on the intakes. I'm gonna run it.
Mopar to the bone!!!
Re: Piston/Valve clearance, how tight have you run? [Re: 72Swinger] #1710089
12/13/14 02:56 PM
12/13/14 02:56 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I thought that I was the only one that did stuff like that!!!! BOTH intake & exhaust on my Gen 3 Hemi were .067"-.070" It's ran fine with No issues @ 8000 RPM.
If you like drag racing, support your local track.
Re: Piston/Valve clearance, how tight have you run? [Re: CHAPPER] #1710090
12/13/14 03:24 PM
12/13/14 03:24 PM
nielsville, minn.
Q
Q
nielsville, minn.
I've got one on the stand right now that REAL tight. Trying to decide if I should try it or not. Intake is at .045 and exhaust is at .060 WITH lash. Quench is at .040. Motor is a 426 wedge with the low compression Max-Wedge pistons, compression works out to 13.72-1. Dave
Re: Piston/Valve clearance, how tight have you run? [Re: quickd100] #1710091
12/13/14 03:41 PM
12/13/14 03:41 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is tight tight ^^^^^^. Don't want to kill the quench, so I guess its cut the pistons time or roll the dice.
Re: Piston/Valve clearance, how tight have you run? [Re: quickd100] #1710092
12/13/14 03:41 PM
12/13/14 03:41 PM
gregsdart Offline
gregsdart  Offline
Dave, I think that is too tight. For sure on the exhaust, as any failure of the valve to follow the cam and ya got trouble. With only 0.040 piston to head, when a lot of that is eaten up at speed you are down to about .020 or .030 from crashing the exhaust valves. Any inconsistency in valve depth in the heads will add to the problem, along with any other items that are a bit off.
Re: Piston/Valve clearance, how tight have you run? [Re: quickd100] #1710093
12/13/14 03:54 PM
12/13/14 03:54 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I believe I would do some piston cutting on that one. I got tired of taking pistons out of the Hemi and settled with what I got on the last cut/ check.
Re: Piston/Valve clearance, how tight have you run? [Re: quickd100] #1710094
12/13/14 04:01 PM
12/13/14 04:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Throw a little thicker gasket on it.. yeah we all try
for .040 quench but a bit more isnt gonna kill you
but a crash of a valve sure will... I ran a SB with
.045/.055... it cleared but the valves were right
there on the pistons.. I actually had to clearance
3 pistons on the first tear down where I could see
a slight touching... I didnt even bother with a re-balance..
that was with tight piston to bore pistons... rocking
the piston will tell you more
Re: Piston/Valve clearance, how tight have you run? [Re: CHAPPER] #1710095
12/13/14 04:06 PM
12/13/14 04:06 PM
nielsville, minn.
Q
Q
nielsville, minn.
Well the issue settled itself. With initial clearance checks I started checking every valve and found one cylinder that had .009 clearance p/v. I've got another set of heads that haven't been milled as much.They will bring the compression down to 11.76-1 and are a set of 516's. didn't really want to use them as the flows will be off a bit.Dave
Re: Piston/Valve clearance, how tight have you run? [Re: gregsdart] #1710096
12/13/14 10:39 PM
12/13/14 10:39 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree. For a super stocker or some class rules that might be fine. But if you don't check and replace valve springs, etc. very often you could hurt something real bad. Over rev it by accident (water box, missed shift, tire spin, etc.) same damage. Not worth it for most of us, IMO.
Re: Piston/Valve clearance, how tight have you run? [Re: quickd100] #1710097
12/13/14 11:09 PM
12/13/14 11:09 PM
Out of the State of Confusion
blue_stocker Offline
Having run S/SS for several years I know and have formed my own 'dimples' when the P/V clearances were TOO close (.040"). In stock, we take lots of chances because we're stuck with non-reliefed/flat top pistons and quite often, run-what-you-brung situations with our engine parameters, which can end up with disastrous results (getting the aforementioned 'dimples'/ forging our own reliefs or worse, ouch). Nonetheless, a good rule-of-thumb is .080" piston to valve at the closest point. Some say .080" intake, .100" exhaust, so if you have the option to modify/machine the tops for bigger/deeper pockets, do it! I've also talked to a few engine shops that state absolute minimum piston to head clearance should be .050" in a steel rod engine. I've run as close as .037" with a wobbly .008" skirt clearance to boot without crashing. So...what is the 'correct' clearance? Whatever you can get away with without catastrophic engine damage/failure. Just be aware that the results could be less than positive should you have inaccurate measuring techniques or your choice of clearances be inadequate!
Re: Piston/Valve clearance, how tight have you run? [Re: blue_stocker] #1710098
12/13/14 11:18 PM
12/13/14 11:18 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
True enough. Why would ANYONE try this on a non class style motor? They must have money and time on there hands. Nothin more fun then dropping a valve, well maybe kickin a rod.
Doug
Re: Piston/Valve clearance, how tight have you run? [Re: dvw] #1710099
12/13/14 11:32 PM
12/13/14 11:32 PM
It is easy to forget this rule:
Retard the cam get more room on the intake valve --EASY -- sometimes it is just a case of having cam advanced a little too far -- This can pull you out of a jam and sometimes. ---you find that engine runs better than you imagined with cam in a different position
Fun to note-- that on a dyno --if you take your time and move a cam around a little you discover things that do not fit conventional wisdom ( which is Highly Over rated)
Many cams we know and love like the 590 solid and the world famous .650 lift Comp solid , a cam that is a Herb McCandless original--It loves being in a 440 at 100- 101 range and a 500 at about 104--then it will rock but straight up you would have to turn big RPM to get the juice out of it--
Oops, too close!!! [Re: dvw] #1710100
12/13/14 11:33 PM
12/13/14 11:33 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
A W5 engine I built several years ago was running too close. I had checked all clearences when I built the engine so I was extremely surprised to find that the numbers the head guy stamped into the valves were actually leaving the numbers imprinted on the pistons. I couldn't believe it. Needless to say I ordered some thicker head gaskets to provide some clearance. I went .045 thicker on the head gasket so I had a little room. Fortunitely I built the engine with 14.5 compression so I still had a decent number with the thick gaskets. I've triple checked every one since then.
Re: Piston/Valve clearance, how tight have you run? [Re: quickd100] #1710101
12/15/14 12:47 AM
12/15/14 12:47 AM
Washington
madscientist Offline
Washington
Intake valve clearance does not need to be any more than what your piston to head clearance is. If you can run p/h that is all the intake needs. It is "impossible" for them to hit, unless you have a valve float issue, or some other such problem.
For the exhaust, it is p/h clearance plus .040. Any more than that and you are wasting compression.
Re: Piston/Valve clearance, how tight have you run? [Re: madscientist] #1710102
12/15/14 10:05 AM
12/15/14 10:05 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
No matter how good your springs are you have some "float", piston to head clearance is NOT enough to cover for that.
Timing chain harmonics alone will advance/retard cam timing a bit while running.
Re: Oops, too close!!! [Re: Blucuda413] #1710103
12/15/14 11:53 AM
12/15/14 11:53 AM
Canada
onig Offline
onig  Offline
Canada
I never heard of this. Is stamping numbers on valves a common practice. I never tried it, but it seems it could be difficult with the hardened valve Also I am thinking that the valve may bend when stamping.
Just curious.
69 Dart
Re: Oops, too close!!! [Re: onig] #1710104
12/15/14 03:12 PM
12/15/14 03:12 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
onig, I don't know how prevalent the practice is but this head guy did it on all heads he prepared, very reputable Mopar and other speed/machine shop. These were titanium valves. The reason I tore the engine down was that a roller lifter tie bar broke and I was lucky enough to catch it before the lifter turned and big destruction took place.
Re: Piston/Valve clearance, how tight have you run? [Re: dizuster] #1710105
12/15/14 04:49 PM
12/15/14 04:49 PM
Washington
Washington
That's why I don't uses chains. Period.
If your valvetrain is correct, p/h clearance is enogh for intake p/v clearance. If it's not, use the MoPar standard .100 intake and .120 exhaust.
I've seen junk with more clearance than that hit. So it's a matter of right is right.
