73 Chrysler rubber body mounts. MI company? #1709001
12/10/14 04:16 PM
12/10/14 04:16 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Too much Mopar stuff to remember. My brain is filled with 10,000 gaskets
A customer asked about 73 Chrysler body mounts. Thought remember a MI that did trans mounts and maybe body mounts?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 73 Chrysler rubber body mounts. MI company? [Re: 71TA] #1709002
12/10/14 09:19 PM
12/10/14 09:19 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Jim.. Moparts member cudazappa makes the body and trans mounts from an aluminum alloy...Don't waste your time with the rubber or urethane bushings if you're going in...Firmfeel.com also carries the alloy bushings..I was'nt impressed with any urethane pieces I've swapped out... Some urethane kits require you to reuse the original rubber bushing's metal center support rings which are usually always shot....
Re: 73 Chrysler rubber body mounts. MI company? [Re: 71TA] #1709003
12/10/14 11:39 PM
12/10/14 11:39 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Jim,
You thinking of Imperial Services ?
http://imperialservices.net/
Re: 73 Chrysler rubber body mounts. MI company? [Re: gtx6970] #1709004
12/11/14 02:02 AM
12/11/14 02:02 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks Colin.
THATS them Bill. Thanks. I think Alzheimers is setting in at 52!
