steering column #1708254
12/08/14 03:28 PM
12/08/14 03:28 PM
waverly oh
rdowns Offline OP
rdowns  Offline OP
waverly oh
Any one recommend a place to get steering column restored
Re: steering column [Re: rdowns] #1708255
12/08/14 04:44 PM
12/08/14 04:44 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
There is a guy on ebay that sells lots of restored columns. I bet he could do yours.
Re: steering column [Re: fastmark] #1708256
12/08/14 05:47 PM
12/08/14 05:47 PM
waverly oh
rdowns Offline OP
rdowns  Offline OP
waverly oh
Would that be norms speed shop i just spoke with him
Re: steering column [Re: rdowns] #1708257
12/08/14 07:29 PM
12/08/14 07:29 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Mike Mancini does them in RI
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: steering column [Re: VCODE] #1708258
12/08/14 08:36 PM
12/08/14 08:36 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
You can also do a search for threads on the topic on Moparts. There have been a number of guys who did their own. It's not super complicated.
Maybe someone who has recently done one will chime in with a photo-montage.
Is your column black?
if it is a color, then they will need the color you are painting the other metal parts (lower dash) with.
Re: steering column [Re: RP's R/T's] #1708259
12/10/14 05:37 PM
12/10/14 05:37 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
Premium Interior Restorations in the Detroit area. 248-852-9187
Re: steering column [Re: rdowns] #1708260
12/10/14 06:45 PM
12/10/14 06:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've done several.
Actually have one for a 1968 B body in process now
This one is for a 1970 Charger
Re: steering column [Re: gtx6970] #1708261
12/10/14 06:46 PM
12/10/14 06:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Black one
Re: steering column [Re: gtx6970] #1708262
12/10/14 06:50 PM
12/10/14 06:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1969 B body , column shift
Re: steering column [Re: gtx6970] #1708263
12/11/14 05:13 PM
12/11/14 05:13 PM
NY
clemul Offline
clemul  Offline
NY
I've done several.
Looks great, what do you use to paint shift tube and also gold cadmium?
Re: steering column [Re: clemul] #1708264
12/11/14 06:48 PM
12/11/14 06:48 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I did my own and had never done a column resto before. Not that difficult to do. I used Rustoleum texture paint and was very happy with the end result.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: steering column [Re: clemul] #1708265
12/12/14 10:24 AM
12/12/14 10:24 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've done several.
The blue column the entire shaft was plated yellow zinc,,which is wrong.
The black one just the lever and down is plated and the rest of the tube was left bare steel and treated with RPM
When I did the 1st one I didnt think to ask if just the lower lever could be plated. (now I know )
Basically your asking the plater to do the process by hand
