'71 Cuda headlamp ring stamped nut - what to use? #1708028
12/08/14 12:31 AM
12/08/14 12:31 AM
South Carolina
sixpackbird Offline OP
South Carolina
The '71 'Cuda reproduction grilles don't have the stamped nut crimped on to the post to attach the headlamp rings, what have you used? Does someone sell the original style stamped nuts that are crimped onto these posts?
Re: '71 Cuda headlamp ring stamped nut - what to use? [Re: sixpackbird] #1708029
12/08/14 03:15 AM
12/08/14 03:15 AM
Scottsdale A.Z
71cudaddict Offline
71cudaddict  Offline
Scottsdale A.Z
Same problem bump
Re: '71 Cuda headlamp ring stamped nut - what to use? [Re: sixpackbird] #1708030
12/08/14 08:06 AM
12/08/14 08:06 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
You bought the grille from the wrong supplier, Roseville Chrysler Jeep, as well as our company, supply them with the grilles. Call Dave at Roseville (586-859-2500), he might have some extra he can sell you.
