Scat internal balanced rotating assemblies #1707947
12/07/14 09:16 PM
12/07/14 09:16 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
I was just wondering if they are within in 2 grams as rep said. I have always great success with scat products.
Re: Scat internal balanced rotating assemblies [Re: 71Pan] #1707948
12/09/14 09:36 PM
12/09/14 09:36 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
I sure hope so. Mine just arrived today!
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Scat internal balanced rotating assemblies [Re: fasteddie] #1707949
12/10/14 02:52 AM
12/10/14 02:52 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
great let me know what you think
Re: Scat internal balanced rotating assemblies [Re: 71Pan] #1707950
12/10/14 02:57 AM
12/10/14 02:57 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Brian at IMM Engines said he double checked a rotation assembly and was what it stated.
Maybe he can elaborate?
Re: Scat internal balanced rotating assemblies [Re: autoxcuda] #1707951
12/10/14 02:01 PM
12/10/14 02:01 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Just what does "within 2 grams" mean anyways? Does that imply that the bobweights for each cyl are the same within 2 grams and the crank is balanced to the median bobweight?
The rotating assy I got from Indy fpor the 540 was supposed to be "within 5 grams" and my builder had to do a hellova lot of drilling to bring the crank into balance. He couldn't understand the "5 grams" stuff either.
Good ole Josh...
Re: Scat internal balanced rotating assemblies [Re: autoxcuda] #1707952
12/12/14 12:54 AM
12/12/14 12:54 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
cool
