Page 2 of 3 1 2 3
Re: aluminum sealing washers 4 external oil pan lines? [Re: Jerry] #1707541
12/08/14 12:53 PM
12/08/14 12:53 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
that fitting is already designed with an o ring groove. you need a special o ring to seal it. the washers that I'm making will have the pocket to use this o ring on one side and a groove for an o ring on the other. i'll post a pic after lunch so everyone gets it.
I machine the groove so the o ring stays more on the face and doesn't get squished toward the center where it might get cut easier by the edge of the hole cut in the pan...at least that's what I was thinking the first time I did it and couldn't find the o-ringed washers locally the day I needed them...
Re: aluminum sealing washers 4 external oil pan lines? [Re: MoParFish] #1707542
12/08/14 12:57 PM
12/08/14 12:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707543
12/08/14 02:35 PM
12/08/14 02:35 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Those would look a lot better then the Copper RTV I used. lol
Re: aluminum sealing washers 4 external oil pan lines? [Re: FastmOp] #1707544
12/08/14 02:55 PM
12/08/14 02:55 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
The pickups have an o-ring recess in them. You put the fitting through the hole in the pan, you slip the o-ring over the fitting, you smear pipe sealant on the threads of the fitting, you screw the fitting into the pickup. No fancy washers and no leaks.
But if ya wanna waste time and money ...
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707545
12/08/14 08:21 PM
12/08/14 08:21 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Who makes these Pittsburghracer?
Re: aluminum sealing washers 4 external oil pan lines? [Re: John Burdine] #1707546
12/08/14 08:50 PM
12/08/14 08:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: aluminum sealing washers 4 external oil pan lines? [Re: John_Kunkel] #1707547
12/08/14 08:53 PM
12/08/14 08:53 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I couldn't ever find those to fit the -12 fittings, they didn't go that big and I tried several suppliers. Well one said they made them but would have to buy a box of 100 and weren't going to do that unless I wanted to buy the box so I went with the seals that PittsburgeRacer is showing from DTI. (i'm trying to look up their contact or Website but not finding them)
Earl's doesn't carry -12 either, they stop at -8 or -10 but don't have for -12 or i would have went with the Stat-o-seals.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: aluminum sealing washers 4 external oil pan lines? [Re: WadeMetzinger] #1707548
12/08/14 08:59 PM
12/08/14 08:59 PM
Tulsa, Ok
Tulsa, Ok
Check out my post asking about these earlier this year, if this link doesn't work, I bumped my old post so it would be on the front page.
It has the info for Doty for those seals.
https://board.moparts.org/ubbthreads/show...rue#Post8026707
Re: aluminum sealing washers 4 external oil pan lines? [Re: WadeMetzinger] #1707549
12/08/14 09:16 PM
12/08/14 09:16 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Todd at comp. wedge is a DMI dealer I think.
Re: aluminum sealing washers 4 external oil pan lines? [Re: a493demon] #1707550
12/08/14 09:31 PM
12/08/14 09:31 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
AS bad as I hate to say this.Indy cylinder Head stocks the -12 Washers with the built in o-ring. I know but I had to at least put it out there.
Re: aluminum sealing washers 4 external oil pan lines? [Re: Sammy] #1707551
12/08/14 10:56 PM
12/08/14 10:56 PM
PA.
"Little"John
"Little"John
PA.
Sorry Sammy I just came in from the shop. I'm not even sure he's still in business as the link no longer works. Maybe Jerry will make some up and make them more available.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707552
12/08/14 10:59 PM
12/08/14 10:59 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Those are what I use....Absolutely leak free...
Re: aluminum sealing washers 4 external oil pan lines? [Re: DAYTONA540] #1707553
12/08/14 11:11 PM
12/08/14 11:11 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
My 440 has a single external line and I don't care who stocks the sealing washers, I will place my order tonight
I just hate oil leaks
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: aluminum sealing washers 4 external oil pan lines? [Re: Polarapete] #1707554
12/09/14 12:08 AM
12/09/14 12:08 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
sorry got busy at the shop. the prototypes are done but I didn't get a chance to take pics today. I'll have them posted in the am tomorrow and then will start taking orders for them. the first set I designed to be a -12 but -16 and -24 and -10 could be available if there is interest.
also if anyone is interested I made a weld in port for the -12 fitting since I have all the porting tools in the shop. the weld in bung is threaded and has the o ring groove already so you just screw in your fitting. these can be aluminum or steel. let me know your thoughts.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: aluminum sealing washers 4 external oil pan lines? [Re: astjp2] #1707555
12/10/14 03:36 PM
12/10/14 03:36 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
here are the washers, in the kit you'll get two sealing washers and 4 o rings. the -12 washers will be $15.00 for the pair.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: aluminum sealing washers 4 external oil pan lines? [Re: John_Kunkel] #1707556
12/10/14 03:38 PM
12/10/14 03:38 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we did our best to make the washers as small as possible and they use standard off the shelf o rings.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: aluminum sealing washers 4 external oil pan lines? [Re: Jerry] #1707557
12/10/14 03:42 PM
12/10/14 03:42 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Very Nice, as always Jerry!!
Re: aluminum sealing washers 4 external oil pan lines? [Re: STEFF] #1707558
12/10/14 03:54 PM
12/10/14 03:54 PM
PA.
"Little"John
"Little"John
PA.
There you go. They look very nice Jerry and at a reasonable cost. Don't forget I sent you a PM about your small block valve cover spacers.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum sealing washers 4 external oil pan lines? [Re: Jerry] #1707559
12/10/14 06:18 PM
12/10/14 06:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I don't see how they are going to work, my
Re: aluminum sealing washers 4 external oil pan lines? [Re: Challenger 1] #1707560
12/10/14 06:31 PM
12/10/14 06:31 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
its a little hard to see as the pic is a little blurry but on the side away from the fitting there is a groove for an oring. the o ring seals against the oil pan wall. on the fitting side of the washer there is a special port groove for use with the o ring on AN-12 style port fittings, which is what all the earls and aeroquip fittings are designed around.
these could even be used on both sides of the pan to seal a bulk head extra assurance. so you'd have fitting, washer, oil pan wall, washer and then lock nut. if its still unclear i'll post up a drawing later.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Page 2 of 3 1 2 3
