4.625 stroke in a Indy or KB block #1707509
12/07/14 08:41 AM
12/07/14 08:41 AM
Chesterfield Twp. Mi.
John Burdine Offline OP
will a 4.625 crank have any clearance issues in a standard cam location hemi/wedge rb aluminum block (Indy or KB) using steel rods (Oliver)?
Re: 4.625 stroke in a Indy or KB block [Re: John Burdine] #1707510
12/07/14 08:58 AM
12/07/14 08:58 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My 4.5 stroke crank barely cleared in the World Iron block...I had only about .140 clearance. I had 2.375 journals, you might with 2.2 rod journals. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 4.625 stroke in a Indy or KB block [Re: astjp2] #1707511
12/07/14 09:11 AM
12/07/14 09:11 AM
gregsdart Offline
gregsdart  Offline
Crank pin size? Hemi or wedge? Not sure on the Hemi thing, but the lobes being in different locations might become an issue at some point.
Re: 4.625 stroke in a Indy or KB block [Re: John Burdine] #1707512
12/07/14 09:50 AM
12/07/14 09:50 AM
Jerry Kathe Offline
Jerry Kathe  Offline
No....unfortunately not.
Re: 4.625 stroke in a Indy or KB block [Re: Jerry Kathe] #1707513
12/07/14 10:08 AM
12/07/14 10:08 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
When I went from a 4.15 crank with mopar crank pin sizes to a 4.75 crank with 2.2 pin sizes, (steel rods in both), the extra clearancing was minimal. The rod to cam lobe clearance is .060 at the closest with a large roller in my case. I'm using a MP block.Dave
Re: 4.625 stroke in a Indy or KB block [Re: quickd100] #1707514
12/07/14 10:40 AM
12/07/14 10:40 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Guess I stand corrected - But I will have to also say, I'm not brave enough to cam clearance steel rods after they have been manufactured.
FWIW, I will also use only aluminum in builds of that nature. When I inquired about moving to a longer arm in a standard height block, I couldnt find anyone who supported that idea, so I stuck with the 4.5 and the GRP's. (I have also used BME's)
Using the C fire pattern on a std core camshaft with the tightest BC I could get my grind on, I still had to clearance the already clearanced GRP's
Re: 4.625 stroke in a Indy or KB block [Re: Jerry Kathe] #1707515
12/07/14 10:57 AM
12/07/14 10:57 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I was using Manley sportsmaster steel rods in my 528. The 605 uses a Eagle 7.1 rod, I did NOT have to grind on the rods or the cam lobes.
Re: 4.625 stroke in a Indy or KB block [Re: quickd100] #1707516
12/07/14 11:07 AM
12/07/14 11:07 AM
Jerry Kathe Offline
Jerry Kathe  Offline
QUOTE[ "the extra clearancing was minimal." ]
Guess I was confused....?
Re: 4.625 stroke in a Indy or KB block [Re: Jerry Kathe] #1707517
12/07/14 01:21 PM
12/07/14 01:21 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Here's the internal oiling pickup area. You can also see the bottom bore notch if you look closely.Dave
Re: 4.625 stroke in a Indy or KB block [Re: quickd100] #1707518
12/07/14 01:54 PM
12/07/14 01:54 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
With standard cam height and a BBC 2.2 rod pin a 4.625 will clear the cam with even plate aluminum rods without cutting on the rods. You can run a 4.75 stroke with aluminum rods if you notch the rods. Steel rods make it a breeze.
Re: 4.625 stroke in a Indy or KB block [Re: dthemi] #1707519
12/07/14 02:01 PM
12/07/14 02:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My BME 426 forgings were designed for the 2.375" journal, though mine are 2.200". With a 4.5 " stroke it clears the Mega block with a slight notch. A 4.625" stroke would only be .0625" closer.
Doug
Re: 4.625 stroke in a Indy or KB block [Re: dvw] #1707520
12/07/14 04:29 PM
12/07/14 04:29 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Just assembled a motor with Oliver rods and 4.625" crank with a hemi valve pattern 55mm cam,the clearance was tight (.050" ) but will work, my new motor with the same as above but a 4.750" stroke did require a small amount of material removed from (1,3,5 & 7)rods to clear....that was with a cam that has .540" lobe lift (1.026" at the valve ) both have standard cam heights.
