Re: 408 stroker '99 ram
[Re: Rowden34]
#1707441
12/07/14 12:35 AM
12/07/14 12:35 AM
Posts: 6,019 Salem
Grizzly
Moparts Proctologist
Salem
Stock computer?
If the compression ratio is close to stock and the cam is stock, I believe so.
It's an idea I've certainly given consideration to but my 360 won't give up.
Mo' Farts
Moderated by "tbagger".
[Re: DaytonaTurbo]
#1707445
12/08/14 03:45 PM
12/08/14 03:45 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
A 318 computer runs a 360 just fine so a 360 computer should be able to run a mild 408 just fine. For a cheap injector upgrade (so the computer don't have to add a bunch of fuel through the trim) you can just get a set of the bluish-grey injectors from a 460 ferd. But like everyone is saying the bigger cam can really screw with the confuser more than the CID, with just a CID increase the bigger injectors would be just fine till you get it fine tuned.
[Re: 72d100]
#1707447
12/08/14 10:48 PM
12/08/14 10:48 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Seriously? gonna spend $5 grand on a 408 stroker motor that's probably capable of 450-500 hp, but you're going to skip out on a $300 tuner?
why bother doing the 408 at all then?
**Photobucket sucks**
[Re: Rowden34]
#1707448
12/09/14 11:45 AM
12/09/14 11:45 AM
Posts: 1,049 ohio
all spooled up
ohio
I think I'm gonna attempt it with stock computer and if it doesn't run well I will get a tuner. I just don't know if it would hurt anything or not.
if it goes lean it will hurt a lot of things like 8 pistons get a tuner
[Re: all spooled up]
#1707449
12/09/14 02:35 PM
12/09/14 02:35 PM
Posts: 6,019 Salem
Grizzly
Salem
OP, do your homework and Google "problems, tuner, Dodge" and see what you come up with. You are on the right track trying the factory set-up first.
Mo' Farts
[Re: Grizzly]
#1707450
12/12/14 12:10 AM
12/12/14 12:10 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
WTF???? if you going 408 get a tuner, look up Ryan Hogan (flyingryan) he can tune your truck with sct tuner. Stock injectors will work up to 415whp then they will start to run out on a 408 stroker. The stock computer will not like the low map signal and dump fuel and run like crap, GET A TOON!
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#1707451
12/12/14 01:58 AM
12/12/14 01:58 AM
Posts: 6,019 Salem
Grizzly
Salem
So if he were to put a 318 crank in a 360 block would he have to get a TOON? How many vehicles did that Marty at KRC eff up? You would have thought that guy was King of the Internet at one point, now he kinda just vanished off the face of the earth, huh? So is this Ryan the new hype for the uncrackable Chrysler computers? Educate me. I want to do a twin-turbo 360 Magnum. Proven waste of money and time as shown in Diablosport and Superchips Forums. SCT doesn't even have forum support. I believe Rick Ehrenberg is the only one who's cracked a Chrysler computer and they had Factory help doing it.............perhaps he can correct me here or offer some clarification. Does this look like a "hand-held" tuning operation to you? Ref: Mopar Action, June 2007.
Mo' Farts
[Re: Grizzly]
#1707452
12/12/14 09:12 AM
12/12/14 09:12 AM
70Cuda383
Marysville, O-H-I-O
SCT works. Period.
KRC is a joke. go onto ANY Dakota forum and start asking about KRC.
Ryan knows what he's doing. See, KRC would offer you "box canned" tunes based on a list of mods done to your engine. there was no feedback loop.
Ryan (FlyinRyan performance), and Sean (hemifever) both do SCT now, and they both want you to have a datalogger and a wideband O2 so that you can monitor what's going on in the engine and your AFRs to ensure you're not rich or lean. THey also don't go "balls to the wall" out of the gate. They give you a very conservative first guess at where you need to be based on your mods, then they sneak up on the tune. Ryan even tells you "DO NOT GO WOT WITH THIS TUNE!!!" He demands to see the datalogs from just a cold start, idle/warm up to see what the engine is doing before he wants you to drive. then, he'll tell you, no more than half throttle. then after afew tunes, he'll give you the go-ahead and say "ok, we're safe now to go WOT, run it out and let's see where we are.
after about 8 or 9 iterations of this, you finally get a tune that is streetable, makes good power, and won't blow up your motor.
I'm running a 222/228 107 LSA cam that idles at 8" of vacuum in my 5.9L Magnum with edelbrock heads, headers, etc (haven't dyno'd with new heads yet, but easily a 400-420 crank hp motor) using a factory computer, stock injectors, and stock sensors. all tuned by SCT.
KRC...lol haven't heard that name in a few years. There's a reason they went out of business, and there's a reason why Ryan had to take a vacation from tuning just to get a break due to the number of people asking him to tune their engines.
I would NEVER do a 408 without having at a minimum, SCT.
[Re: Grizzly]
#1707453
12/12/14 02:41 PM
12/12/14 02:41 PM
slammedR/T
I see you are behind the times and don't have a clue, let me help you. Ryan has already tooned a number of turbo 360 magnum trucks and jeeps, they are fast and run great.
It could be worse, it could be 2003 again when you had to send your pcm to B&G chrysler for a flash to run a R/T headed 408 and hope that mail order toon was close much less good
[Re: Grizzly]
#1707454
12/13/14 12:27 AM
12/13/14 12:27 AM
HotRodDave
Kalispell Mt.
A lot has changed in 8 years since that pic was taken And in case any one is wondering when they say toon, they really mean tune. I don't know if that is a new slang term they are trying to get off the ground or if it was an accident.
[Re: HotRodDave]
#1707455
12/13/14 12:31 AM
12/13/14 12:31 AM
70Cuda383
Marysville, O-H-I-O
Just Chad forgetting he's talking to a bunch of guys about 20 years older than him yes, SCT is good enough for big hp boosted applications. SCT can tune a 5.2, 5.9 series LA based Magnum motors, 4.7L overhead cam motors, 5.7L Hemi motors, pretty sure the 6.1/6.4 Hemis as well (that one I'd need to fact check) as well as the Viper V10 motors. SCT is essentially the hotrodders answer to cheaply re-tuning their factory computers to work with modified modern EFI motors. It is VERY capable
