initial settings for new A arm install #1707369
12/06/14 07:05 PM
12/06/14 07:05 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Im getting ready to install the upper A arms and wondered if anyone has tips for the initial settings on the cam bolts? or do I just install and wait until I get the car back on four wheels to make adjustments?
TIA!
Re: initial settings for new A arm install [Re: LimeliteAero] #1707370
12/06/14 07:20 PM
12/06/14 07:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
TIA!
Do this. Then put the car on the ground. Bounce it, roll it back and forth, get it at desired ride height. Don't tighten the UCA or LCA bolts until sitting on ground near ride height.
Then get a carpenter big L square. Using the rear cam adjuster make the rim a little tipped in at the top about 1/8-3/16". Then take to alignment shop. Or align with your alignment tools.
In picture below right picture is front cam. The front of car is this way ------>
Re: initial settings for new A arm install [Re: autoxcuda] #1707371
12/06/14 07:26 PM
12/06/14 07:26 PM
SE Pa.
SE Pa.
THANKS!
I wont be able to get ride height, the drivetrain isn't in yet.
Re: initial settings for new A arm install [Re: LimeliteAero] #1707372
12/06/14 11:59 PM
12/06/14 11:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
No real reason, but I've always put them in with all the cams going straight down .
Never had an alignment guy scream at me yet
