Custom Pistons #1707236
12/06/14 02:12 PM
12/06/14 02:12 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I'm starting the process of building a new 383 for the roadster. Since it doesn't look like anyone makes forged dome pistons for a 4.28 or 4.31 bore with a 1.32 compression height it looks like I may need to order a set of custom pistons. I basically need the Ross 99499 in a 4.28 bore.
What's everyone's favorite source and what kind of price can I expect?
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Custom Pistons [Re: 69dart] #1707237
12/06/14 02:15 PM
12/06/14 02:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
diamond would be a good choice, but how did you end up with a 4.28 bore why not just go with a common size?
Re: Custom Pistons [Re: Quicktree] #1707238
12/06/14 02:20 PM
12/06/14 02:20 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
A 383 standard bore is 4.25 so .030 over is 4.28 and .060 over is 4.31.
68 Dart - 340
66 Belvedere - 400
Re: Custom Pistons [Re: 69dart] #1707239
12/06/14 02:24 PM
12/06/14 02:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I understand, but i would find and off the shelf piston and go with that bore. be a lot cheaper unless you just want a custom piston.
Re: Custom Pistons [Re: 69dart] #1707240
12/06/14 02:27 PM
12/06/14 02:27 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I would call Ross. They can fix you up. I would estimate $900 w/pins.
If you like drag racing, support your local track.
Re: Custom Pistons [Re: 69dart] #1707241
12/06/14 02:32 PM
12/06/14 02:32 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
RaceTec. If they make it from one of their AutoTec forgings less than $700. I was recently quoted $685 directly from them for a 4.28 replacement for the old TRW 2293 heavy dome piston with 22cc dome only in a 1.53CH. If a member here is a dealer you may find better pricing. Their AutoTec shelf offerings are nice for the money.
Re: Custom Pistons [Re: GTS340] #1707242
12/06/14 03:10 PM
12/06/14 03:10 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I used JE pistons this time around for my new (bigger) predator shortblock. pored a chamber mold, told them what options i wanted,pin height,ring package,exc. and had them in two weeks...I was a ross piston guy for years, but after seeing the quality and fit JE pistons puts out there im changing brands for good..... BTW there about the same price as ross..
Re: Custom Pistons [Re: boatracer572] #1707243
12/06/14 03:11 PM
12/06/14 03:11 PM
San Jose Ca.
San Jose Ca.
this is the mold I poured...
Re: Custom Pistons [Re: boatracer572] #1707244
12/06/14 03:22 PM
12/06/14 03:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using JE`s for as long a I can remember.
Re: Custom Pistons [Re: Thumperdart] #1707245
12/06/14 03:29 PM
12/06/14 03:29 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Used Ross the first time and Diamond the second. Quality was nice with both.
Re: Custom Pistons [Re: 69dart] #1707246
12/06/14 03:48 PM
12/06/14 03:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You do realize that you don't have to do anything in equal increments right. What I mean is.....if you have to order a custom piston anyway, bore it enough to straighten the bore, whatever that number is and order a piston made to fit that bore. No need to go exactly .030 or .060, unless you just want it that big.
Personally, I use nothing but Diamond or Venolia
Monte
Re: Custom Pistons [Re: 69dart] #1707247
12/06/14 04:13 PM
12/06/14 04:13 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the ROSS custom pistons dome are around $1100-1200/set last set my friend bought?
Re: Custom Pistons [Re: 69dart] #1707248
12/06/14 04:50 PM
12/06/14 04:50 PM
Texas USA
N
NBTXDART Offline
NBTXDART  Offline
N
Texas USA
I Have A Set Of JE's 0.30 With 20 Runs On Them. Will Let Them Go.I'll Post Pics Later This Weekend
Re: Custom Pistons [Re: NBTXDART] #1707249
12/06/14 05:27 PM
12/06/14 05:27 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
My last set of custom pistons was bought through Scott Brown and came from CP.
Scott quoted me prices for Ross, Diamond and CP, but recommended me to go with CP.
Really nice finish and fit.
Re: Custom Pistons [Re: RT540] #1707250
12/06/14 05:30 PM
12/06/14 05:30 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I think Diamond has a shelf piston for that combo.
Re: Custom Pistons [Re: fbs63] #1707251
12/06/14 05:46 PM
12/06/14 05:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would talk to Diamond.. they should have a shelf
piston and if you want to move the CH from stock then
its a $35 charge.. they allow 2 changes to a shelf
piston.. anything more and its called a custom piston..
my last set from them I changed the CH and added a
22cc dish so I could have a good quench and the compression
I wanted (pump gas stuff)... they had them for me
to pick up in 4 days
Re: Custom Pistons [Re: fbs63] #1707252
12/06/14 06:04 PM
12/06/14 06:04 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
They dont. They have a flat top but no dome listed. I doubt putting a shelf dome configuration on a shelf flat is a $35 change because it would require a bigger blank. Worth checking though.
Re: Custom Pistons [Re: GTS340] #1707253
12/06/14 06:59 PM
12/06/14 06:59 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
If I could get the 4.375 piston in a 4.31 that would be perfect. If its really going to run $1100 I may just scrap the 383 blocks and find a 400 block since I'm pretty much starting from scratch anyway.
I'd be fine running the old domed TRW's if I could find another set.
68 Dart - 340
66 Belvedere - 400
Re: Custom Pistons [Re: 69dart] #1707254
12/06/14 07:09 PM
12/06/14 07:09 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
http://www.racetecpistons.com/
Great price, nice product! Get exactly what you want for around the price of a shelf Ross. Owned by Wayne Brooks formerly of JE
Re: Custom Pistons [Re: GTS340] #1707255
12/06/14 09:11 PM
12/06/14 09:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If your going custom find an easy ring size you like and build to it. It would be bad to have a custom piston and custom ring. If you ever hurt something it will pay off.
