Re: 1970-71 Wiper Motors
[Re: Mastershake340]
#1707069
12/06/14 04:18 AM
12/06/14 04:18 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
The yellow and black labels don't normally have the same P/N as what is stamped in the motor. The motor on your 71 was probably a factory replacement.Use the core you have to get the correct motor for your car.
NS1AAR
[Re: ns1aar]
#1707070
12/06/14 05:35 PM
12/06/14 05:35 PM
Posts: 674 Kennewick, Wa.
71vert340
Kennewick, Wa.
Thanks for the responses. Ns1aar, your response encouraged me to carefully remove the sticker from the wiper motor. You were correct. The number under the sticker was 3431408 which I can't find what it was for. The wiper motor installed now was either installed sometime between Dec 1970 when the vert was built and July 1, 1972 when I bought the car or the factory installed it. I now may have my spare restored and install it in the car although the date of the one in the car now is closer to the car's build date as you can see in my original post, but only by about two months or so. Does this seem the best route to go? Any idea what body the 3431408 was for? Terry
[Re: 71vert340]
#1707071
12/06/14 08:10 PM
12/06/14 08:10 PM
ns1aar
ontario calif
The 3431408 motor was used on 71 A-bodies only. As far as the date code on the other motor it seems date codes run aprox 30 to 180 days before SPD of course with Chry that's not firm. I have date codes closer to Dec if that's what you want.
NS1AAR
