2001 dakota lift kit? #1706653
12/04/14 03:32 PM
12/04/14 03:32 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So what lift kits are there to lift a later 4x4 dakota? What to use and what to avoid? Just need a couple inches for a customer.
Re: 2001 dakota lift kit? [Re: HotRodDave] #1706654
12/04/14 04:50 PM
12/04/14 04:50 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I have an 03 I looked into kits awhile back.
Unless you want to pay$$,body lift or blocks and crank on the torsion bars.
Re: 2001 dakota lift kit? [Re: moparborn] #1706655
12/07/14 12:55 AM
12/07/14 12:55 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
While researching today, I ran across this at Allpar.
I don't know enough about lift kits for these to say if there is a GOOD one out there, but this says the cheap/quick method is not good for this guy.
http://www.allpar.com/trucks/dakota-1997.html
Lift kits
Suspension engineer Bob Sheaves wrote:
Look at how people lift Dakotas (I am speaking specifically of the 1997 to 2004 here) with $130 torsion bar keys and rear spacer blocks. If all you want to do is fit 33 inch tall tires, fine. It is cheap and will do just that...
...as well as destroy halfshaft joints, cause vibration in the driveline, potentially have contact between front headpipe and front driveshaft.....
“Sweating the details” is what causes the costs that many people don't want to pay for. Few will care too much about all that “excess cost”...until parts start to fail due to ignorance of systems integration.
Also consider — the larger diameter tire increases the force moment arm acting on the brakes, causing longer stopping distances.
Re: 2001 dakota lift kit? [Re: HotRodDave] #1706656
12/07/14 01:08 AM
12/07/14 01:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Dakotas are the worse truck to lift. Big bucks to do it right and limited kits due to lack of popularity.
Re: 2001 dakota lift kit? [Re: moparborn] #1706657
12/12/14 10:46 PM
12/12/14 10:46 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
How much can you safely lower the front of a 2001 Dodge Ram 1500 with the torsion bars?Thanks
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 2001 dakota lift kit? [Re: MRMOPAR622] #1706658
12/13/14 02:41 AM
12/13/14 02:41 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
at one time i bought a 02 dakota quadcab 4x4 that had a 3 inch body lift on it,it was easy to remove,just some pucks and long bolts,a link in the steering shaft and a short extension on the lower radiator hose,i shipped the kit to a guy in the carolinas for$100 and we were both happy!
my ladder of success is missing some rungs
