Does anyone recognize this wire? E-body rear marker #1706055
12/02/14 07:52 PM
12/02/14 07:52 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I recently bought a set of side marker from Barry and it had a wire (obvious ground) coming from the driver's rear, probably attahced to the tail light retaining nut. Is this a factory wire? Definitely has a purpose and will be used.
Careful, your character's showing!
Re: Does anyone recognize this wire? E-body rear marker [Re: mopar346] #1706056
12/02/14 09:05 PM
12/02/14 09:05 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Doesn't look factory to me. And i'm not sure how much it would help anything either.
The issue I kept running into was corrosion right around the socket. Lights stop working, pull out the small wire brush, remove the connector, brush the edges good, plug it up and it worked again for a while.
Finally I added ground wires by soldering a wire directly onto the metal light socket pigtail and then ran it to a cleaned up bolt head slathered with dielectric grease. Not a problem since.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Does anyone recognize this wire? E-body rear marker [Re: Michael Ecks] #1706057
12/03/14 07:03 AM
12/03/14 07:03 AM
Australia
Teamx Offline
Teamx  Offline
Australia
there is an earth wire on the LH rear side marker to tail light to provide earth for the tail light body. the RH tail light earths from the trunk lock rod cover.
Re: Does anyone recognize this wire? E-body rear marker [Re: Teamx] #1706058
12/03/14 08:44 AM
12/03/14 08:44 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you, I knew it looked factory but just wasn't sure which factory it was from. Barry or I neither one remembered seeing one before, but I'm not an E-body guy.
