Re: Need opinions on Antifreeze / Radiators
[Re: 69/70 Plymies]
#1705806
12/02/14 02:06 PM
12/02/14 02:06 PM
RapidRobert
You used the good original "green" stuff if I'm reading this right (I forget if that is zerex or prestone) & distilled water so that is perfect. all I can add is people have said to avoid the orange death (dexcool?). OT People have added several drops of liquid dish soap for a poor mans' water wetter and a bit of baking soda as an acid neutralizer. I would flush it out good & refill with distilled water/original green antifreeze (refresh me, is the green P or Z ?) just like you originally did & continue searching for a good answer on where the corrosion came from, if it is just natural deterioration. PS that was a brass radiator correct?
[Re: 69/70 Plymies]
#1705807
12/02/14 02:06 PM
12/02/14 02:06 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
I bought the local stuff and it started turning acidic. I flushed it and added Prestone...couldn't get the pH over 8. I am convinced it was the "distilled" water. I think the bottle manufactruers just fill it up from the tap and sell it as purified. Those white specks you saw might be broken down mineral deposits in your mixture.
I went ahead and bought de-ionized water and pure Military Spec Ethylene Glycol...so pure...that it was clear in the container. I added the green dye myself. My pH is now 9.x and mixed to 50/50. I wouldn't know the first place to look for pure ethylene glycol in the U.S. but if you can track it down with de-ionized water (think steam irons for clothes).
If you have any aluminum parts on your setup, do yourself a favor and run a few sacrificial anodes. I got mine from Boatzincs.com and I also run a radiator cap with a spring attached to the cap connected to another sacrificial anode there (eBay) it free flows in the coolant of the radiator.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: 69/70 Plymies]
#1705810
12/02/14 05:00 PM
12/02/14 05:00 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
RapidRobert, Yes,the Zerex is green. Don't know the color of the Prestone. And yes, the radiator is the brass type.
Been using Prestone 43 years in my 71 Corvette, changed every 2 years,,,few miles,,odometer now at 78,000. Use Prestone reverse flush 5 dollar kit to change. Original Prestone has always been green, but do remember another brand as orange many years ago,,,,zerex?????
Zero issues with radiator or heater,,,still original,,,water pump replaced once.
[Re: jbeintherockies]
#1705815
12/03/14 10:39 AM
12/03/14 10:39 AM
Pyper70
Athens, Greece
I checked the same thing with the voltage..I had .435v ...I wanted the sponge from VE labs but they dont have them in stock anymore...Also wanted the heater hose in-line filter to help the system.
[Re: ademon]
#1705819
12/04/14 01:18 AM
12/04/14 01:18 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Yup. I remember that. I believe it wasn't an anti-freeze manufacturing plant but where the ethylene glycol itself was being produced. Here's a link to a pdf chart for which coolant has what, what its for, and what color it is dyed. It's just for the Valvoline-zerox brands. I've been buying the 'maxlife' which is a conventional inorganic coolant. http://www.whitfieldoil.com/downloads/ZerexAntifreezeLineupChart.pdfThat chart is from 2003. Some folks at on the oil forums e-mailed valvoline in 2012. Maxlife is now dyed yellow, but otherwise seems fairly similar to earlier incarnation. http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2491912/2
[Re: ademon]
#1705820
12/04/14 01:20 AM
12/04/14 01:20 AM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
At one time wasn't there only two or so plants making antifreeze and one was damaged sending prices up?
Yes, that was an ethylene glycol plant in the early 2000's. Since repaired. Ethylene glycol is used in many industries (nylon plastics is big).
[Re: Pacnorthcuda]
#1705821
12/04/14 01:36 AM
12/04/14 01:36 AM
Posts: 4,963 WI
Dcuda69
WI
