r5 p7 power glide adapters and flex plate #1705684
12/02/14 02:03 AM
12/02/14 02:03 AM
Madisonville, KY
blue64plymouth Offline OP
Madisonville, KY
I have put a r5 p7 in my daughters duster bracket car and we have beat the motor to death with no issues so i decided to put one in my 64 plymouth but didn't have an 8 bolt flex plate so i called Eric at JW performance in fl and he made the flex plates and hubs for the 8 bolt and the 2 different 6 bolt plates.So if anyone is considering this combination jw has these in stock and Joey Arrington at REP in N.C makes the adapter plate for a glide and also sb mopar adapter,you will have to drill and tap the plate for standard mopar starter as the jw wheel is standard 130 tooth.REP also has 100 of these motors and tons of parts for them as well.
Re: r5 p7 power glide adapters and flex plate [Re: blue64plymouth] #1705685
12/03/14 12:24 AM
12/03/14 12:24 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
How are you supporting the nose of the starter?
If JW is making this flexplate that is good to know. I tried getting them done by them. Never got back to me. So QuickTime is doing these flywheels to go with my bellhousings. They cert 30.1.
You guys with adapters need more spacing built into the flexplate to allow for the adapter. I only have 3/8" built into my flexplate to match a would be LA crank.
Would like to get more info on these flexplates. I have to buy 5 at a time with QuickTime.
Re: r5 p7 power glide adapters and flex plate [Re: Leon441] #1705686
12/03/14 02:04 AM
12/03/14 02:04 AM
Madisonville, KY
Madisonville, KY
Hey Leon,i use a standard small truck starter,it bolts directly to the adapter plate but has to be spaced out just a bit, the starter nose isn't supported,i have been running it like this for years with my old w8 motor also.Give Eric a call at jw,he has the flex plates and crank adapters on the shelf now,if you need one.These little motors are very reliable,we have 560 passes on it this year,and it was just a takeout motor,we didn't change anything,just bolted our rons alky injection on.The car weighs 2600 lb with her in it,shifting at 7800,it runs 5.50 at 124mph best,Thanks
Re: r5 p7 power glide adapters and flex plate [Re: blue64plymouth] #1705687
12/03/14 07:14 AM
12/03/14 07:14 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Blue64plymouth care to share the specs on that Duster?
Re: r5 p7 power glide adapters and flex plate [Re: blue64plymouth] #1705688
12/03/14 01:59 PM
12/03/14 01:59 PM
Renton Washington
Triple Threat Offline
Renton Washington
Wow, I'm impressed to say the least!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: r5 p7 power glide adapters and flex plate [Re: Triple Threat] #1705689
12/03/14 02:40 PM
12/03/14 02:40 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Why shift at only 7800?
Re: r5 p7 power glide adapters and flex plate [Re: sshemi] #1705690
12/03/14 04:22 PM
12/03/14 04:22 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
My guess would be consistency and easier on valve train. I've met Mike and his family, they truly are good people! Bethany is a hell of a driver and the Duster has been a winning ride for some time.
Hopefully the guy who's got the old combo can get it to run just as good as you had it running Mike! .......
Re: r5 p7 power glide adapters and flex plate [Re: SpareParts] #1705691
12/03/14 04:45 PM
12/03/14 04:45 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Any pics of the car and engine?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: r5 p7 power glide adapters and flex plate [Re: Eric] #1705692
12/03/14 07:01 PM
12/03/14 07:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
No sure how its making that much power down low?? Is it a short track engine?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: r5 p7 power glide adapters and flex plate [Re: DemonDust] #1705693
12/03/14 07:35 PM
12/03/14 07:35 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I agree. Most ive seen makes peak power around 8800rpms
Re: r5 p7 power glide adapters and flex plate [Re: Eric] #1705694
12/03/14 08:33 PM
12/03/14 08:33 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I don't think I have any. I don't want to speak to much for Mike but if he chimes in I'm sure he'd answer your questions. I know he's a busy dude.
Re: r5 p7 power glide adapters and flex plate [Re: SpareParts] #1705695
12/03/14 09:05 PM
12/03/14 09:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My buddy had an r5 p7 in his 3000 pound dart and he only shifted it at 7800 or so.
Ran high 5's low 9.40's
Was a restrictor plate motor.
12 to 1 and the cam was only 248/258@50.
So I am not surprised a 400 pound lighter car is running those numbers at that rpm.
Those little motors make lots of steam. He had his heads flowed at a very reputable shop and they inched over 400 cfm.
Best bang for the buck out there.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: r5 p7 power glide adapters and flex plate [Re: blue64plymouth] #1705696
12/03/14 11:27 PM
12/03/14 11:27 PM
PA
R5P7 Bantam Offline
R5P7 Bantam  Offline
PA
Mike,
It's time to remove that BB in the dragster and drop in a R5P7. Then we won't have to scramble looking to prime that pump all the time, lol.
I have over 400 runs on my r5p7 and it hasn't so much as loosened the lash by .001. It's truly a waste of energy to remove the valve cover and look......nothing changes.
Oh, and if you guys are curious, I buzz the sh@#$ out of my motor 9000+ every run. Just ask any announcer at any big dollar bracket race. That little 358 out runs most 582 chevies on the back half as well ( 143.5 @ 660' and 178.5 @ 1320)
Guys, the moral of the story is......quit whining about how nascar motors don't do this or can't do that.......PUT YOUR CARS ON A DIET and ET's will improve drastically.
Mike
Re: r5 p7 power glide adapters and flex plate [Re: R5P7 Bantam] #1705697
12/04/14 01:02 AM
12/04/14 01:02 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I wish I had went with these engines years ago.
I don't need to call jw sense I already have flexplates made. If you read my post you can see we have a sfi 30.1 bell to go behind these engines and use Reid cases. No sheilds, adapters, or any tricks. Just bolt it in and go. Should have on display at QuickTime booth and race parts liquidators.
Re: r5 p7 power glide adapters and flex plate [Re: sshemi] #1705698
12/04/14 01:56 AM
12/04/14 01:56 AM
Madisonville, KY
Madisonville, KY
We actually shifted it at 8600 for half the season and was trying to slow the car down a little so we short shifted it at 7800 and it ran exactly the same so we have just left it there.it has been 1.19 in 60 ft,leaving at 5200.It has a 1.80 low gear glide,15x33-15 tires,probably would be faster with smaller tire too. If i can figure out how to post a picture i will get it on here shortly.
Re: r5 p7 power glide adapters and flex plate [Re: R5P7 Bantam] #1705699
12/04/14 02:00 AM
12/04/14 02:00 AM
Madisonville, KY
Madisonville, KY
540 is out and for sale,i ordered the plates to put r5 in yesterday,so we should be ready for new years race.
Re: r5 p7 power glide adapters and flex plate [Re: blue64plymouth] #1705700
12/04/14 03:15 AM
12/04/14 03:15 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I cant wait to see it.
Mike will you have it ready for the Hang over race at Montgomery?
Re: r5 p7 power glide adapters and flex plate [Re: SB412DUSTER] #1705701
12/04/14 12:26 PM
12/04/14 12:26 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Sorry to go off topic alittle but what gas are you useing for these motors?
Mine came with sunoco premium witch is 115 octan i cant see that being needed at only 12-1?
Re: r5 p7 power glide adapters and flex plate [Re: sshemi] #1705702
12/04/14 07:11 PM
12/04/14 07:11 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Sunoco 112 blue due to rpm. A lower rpm could run 110 purple.
Re: r5 p7 power glide adapters and flex plate [Re: Leon441] #1705703
12/04/14 07:21 PM
12/04/14 07:21 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Probably overkill but I use VP C14 since i'm cranking it 9000+
SDG Motorsports
