Page 2 of 5 1 2 3 4 5
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705475
12/02/14 12:54 AM
12/02/14 12:54 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nice! The car leaves great. Love it! Wait till you dial it in...
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705476
12/02/14 01:16 AM
12/02/14 01:16 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
107 ICL hey?
Says it all about the OTS cr@p most of us settle for with 112 and 114 install lines....
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Moparmal] #1705477
12/02/14 01:55 AM
12/02/14 01:55 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
107 ICL hey?
Says it all about the OTS [Email]cr@p[/Email] most of us settle for with 112 and 114 install lines....
On that note, Steff, with your belt drive, can you easily move the ICL to 112 and run the car to see what might happen?
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705478
12/02/14 02:16 AM
12/02/14 02:16 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
107 @ 3,450 is still 660hp out of 400"...
If you can't handle the truth, you're living a lie.......
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Big Squeeze] #1705479
12/02/14 08:49 PM
12/02/14 08:49 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Glad to see you getting her dialed in. Glad to see the radials hookin and bookin for ya.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705480
12/02/14 09:24 PM
12/02/14 09:24 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Thanx Guys! The car weighs 3450 with me in it. Car has Chassisworks 36" Ladder Bars, Ford 9" with 4.57 gears, Single Adjustable Varishocks on rear, Wilwoods all around, I built my own tubular front end with rack, still using 6 cyl. torsion bars, Afco Single Adjustable Shocks in front, Turbo 400 trans with Griner Brake, UCC 8" Converter, hits at 5500, best 60' was setting the launch rpm at 5000 rpms, MT 315 Drag Radials on a 12" rim, set at 18 psi, Quick recap on motor, motor is 400", 11.6:1, Ported 6.1 heads with 2.10 & 1.65 valves, Stock Rockers, Custom rocker stands, Cam is from LSM, 244/250 .650 lift on a 112, in at 107, Muscle Motors Intake, Custom Cam Belt Drive I designed, Custom Oil Pan with Petersen Single Stage belt driven pump, Pro Systems 1100 Dominator. 18 months ago, when I finished the motor, I dyno'd it and it made 784/650. BUT, after running it all summer, I no longer believe in the number, as the best ET I got doesn't reflect it. I've tuned on the motor for best ET & MPH and I don't think it has anymore in it. I'm pulling the motor out shortly, to take a peak into it and make a couple small changes. Also, I want to see how the cam belt drive I designed has held up, so I can make any necessary tweaks before I start making them to sell. And so far, it has performed flawlessly!!
All of my testing has been 1/8 mile since the closest track is 1/8 mile. I may try to get out one more time at a 1/4 mile track, if I can find one open, the weekend after next.
Your 1/8 mile is 10:02 on Wallace calculator. Not to shabby for a limited engine. You done a very good job with all the small stuff.
I thank you for the info that you have shared.
Matt
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: MattW] #1705481
12/02/14 09:41 PM
12/02/14 09:41 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Love it! Glad she's running well
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Moparmal] #1705482
12/02/14 11:14 PM
12/02/14 11:14 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
107 ICL hey?
I have a 106* LSA in at 106* ICL 238/242 @ .050"
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705483
12/02/14 11:29 PM
12/02/14 11:29 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If you like drag racing, support your local track.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: CHAPPER] #1705484
12/02/14 11:45 PM
12/02/14 11:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice runs
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: FastmOp] #1705485
12/03/14 12:19 AM
12/03/14 12:19 AM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
Looks and sounds awesome Steff. Love the launch!
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: CHAPPER] #1705486
12/03/14 12:22 AM
12/03/14 12:22 AM
Moparmal Offline
Moparmal  Offline
107 ICL hey?
And Im thinking you would almost certainly be getting better low and mid range torque than if you bought one of the off the shelf cams available and just put it in straight up.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Moparmal] #1705487
12/03/14 01:13 AM
12/03/14 01:13 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
107 ICL hey?
I did a Bullet .583 .583 234 238 @.050 on a 110 in at 106 and am going to use a modman with 2 500 eddies I put a loose 10 inch converter in it with 4.10 gears once I get it going I will report
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: biff426] #1705488
12/03/14 01:22 AM
12/03/14 01:22 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Hey Steff, just curious because I know basically nothing about those motors....What are the advantages to building one of those versus a big block?? Is it cheaper??
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Big Squeeze] #1705489
12/03/14 01:45 AM
12/03/14 01:45 AM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Hey Wayne, Big Block power in a lighter, smaller package? I dunno, I just love these motors and I'll never build anything else. Stock blocks holding up to good power....stock heads, cnc ported flowing 360+ cfm. Cost wise, good parts cost what they do regardless of platform. To me, it's build what makes you happy. These make me happy.
Thanx Guys!
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705490
12/03/14 02:28 AM
12/03/14 02:28 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
steff great job, saw the facebook video and the car is awesome. guess your front end Is up to the task with street miles and coming down after the launch.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: biff426] #1705491
12/03/14 07:10 AM
12/03/14 07:10 AM
Moparmal Offline
Moparmal  Offline
107 ICL hey?
I think we'd all be interested in that Biff...or should be...
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Moparmal] #1705492
12/03/14 12:56 PM
12/03/14 12:56 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Congrats Steff, love the car!
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705493
12/03/14 02:54 PM
12/03/14 02:54 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Awesome. I really wasn't expecting wheels up like that!
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: 68KillerBee] #1705494
12/03/14 03:22 PM
12/03/14 03:22 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Very nice Steff!
