Right Stuff R/Disc Kit
#1705204
11/30/14 08:55 PM
11/30/14 08:55 PM
Posts: 952 Queens, N. Y.
FASTBACK340
Queens, N. Y.
I'm thinking of upgrading the brakes in my car, a '68 Barracuda. I want to swap out the 10" drums and go with disc in the back, as I already have the 4 piston factory discs up front. Here's my concerns.
Has anyone used The Right Stuff rear disc brake conversion? I know it's 90's Ford T-bird calipers with built-in parking brakes. Can it be obtained with the 4" bolt pattern? (I already own the rims, the front are disc already)
Which master cylinder would I use for manual brakes with the above disc set-up?
Should I invest in the braided flex hoses at this point too along with DOT 5?
Should I scrap the Kelsey-Hayes front 4 piston units and just upgrade to the 4.5" bolt pattern late model brakes and get my polished Weld Pro Stars I want so badly I twitch....
I'm trying to upgrade my brakes without breaking the bank, which can easily happen here!
`68 Barracuda 340-S
Re: Right Stuff R/Disc Kit
[Re: FASTBACK340]
#1705205
11/30/14 09:19 PM
11/30/14 09:19 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You are either looking at upgrading to the large lug pattern or finding an import rear disc setup (5x100) and doing something yourself.
I'm no pro but I am not aware of any small pattern kits.
[Re: FASTBACK340]
#1705211
12/01/14 11:02 PM
12/01/14 11:02 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
I have the Doctor Diffs rear Cobra set up in small bolt pattern. Had it for a few years, works great.
What master cylinder are you using? Adjustable proportioning valve? Power or manual? Over the winter I want to upgrade the brakes for sure, but I don't want to change the bolt pattern or spend $700. And on the Dr. Diff web site there's no mention of bolt patterns. Even if they still offer the SBP, $700 with e-brake cables.....
Is this mostly for appearance? The actual amount of braking the rear does in these cars is minimal. I have upgraded both mine to rear disc, and to be honest, it does very little for braking, particularly if you have the 10 inch drums...
[Re: Tomswheels]
#1705212
12/01/14 11:25 PM
12/01/14 11:25 PM
FASTBACK340
Queens, N. Y.
I want to upgrade my brakes and am asking for advice on a good performing, reliable, reasonably priced system. That's why. Appearance......
`68 Barracuda 340-S
[Re: 68cuda440]
#1705218
12/03/14 04:09 PM
12/03/14 04:09 PM
Posts: 19,587 north of coder
moparx
It took me a long time to find a 5/16" master... No you are correct I am using a 15/16" master.
The 5/16" master had a pretty low effort but the pedal travel, at roughly 2 feet, was a little excessive...
-Michael
puts meaning to the phrase " putting your foot through the fire wall" ........
[Re: FASTBACK340]
#1705219
01/01/15 09:57 PM
01/01/15 09:57 PM
Posts: 52 Texas
shart70rt
Texas
I used their kit, worked well. If I had known about the Dr Diff kit, may have gone with it. Have mine on a b body Dana 60. Changed the axles at the same time, just for freshening.
Kit came with a Wildwood manual master cylinder, 1 1/16 I believe.
70 Go Mango Charger RT White Vinyl Top 18 Spline 4 speed Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing 505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
